Question about GE WPGT9360E Profile Harmony 4.0 cu. ft. Washer with Stainless Steel Basket
Notice there is a problem detected with this unit
It won't do anything except display that notice
Problem detected with this unit on the display won't function
Did it "seem" unbalanced, or "sound" unbalanced. Can you turn the unit on and then get the fault message, or is system locked in fault? You can download the manual at:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=WPGT9360EPL
Look through the troubleshooting section and see if it can answer your questions. Also, warranty information is located in the manual as well ;-)
Apr 02, 2013 | Washing Machines
Pioneer deck powers on but won't play, just flashes 0000 on both timers
Units that sit do not exercise the belts and this causes some belts to become deformed and then other to just decay to like a tar. Look inside the unit to see if the motors are turning. If they are you will see it needs new belts. If the motors are not turning then the likely cause is Electrolytic Filter capacitors in the power supply. They don't do well sitting either.
Jan 27, 2013 | Audio Players & Recorders
Elctrolux dishwasher won't start, display won't light and it randomly beeps
Check continuity of the 4 small wires that connect to the control panel to the control board. They seem to break where they flex for the door to open and close.
Jul 25, 2012 | Electrolux EWDW6505GS Fully Integrated...
Hp photosmart premium wifi failure
@ Other computers might be beyond the range of wi fi limits, run the CD in other computers ask to detect.. if not detected suspect out range.Check obstructions of walls, beams, magnetic fields.
@ If printer is not scanning check whether copy happening or not, if copy is happening uninstall the drivers and reload it once again, if copy not happening check scanner unit warming up or not.
Nov 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
Your website won't give me anything except that I am running an outdated version of Firefox. When I click on download new version, I got the following: Unfortunately the latest version of Firefox...
Hi There, I'm having some problems with Firefox also.Went to Google Chrome and it is fast becoming my default browser.The favorites is a star in the address bar and the wrench has bookmarks and every thing else you need.At this time Chrome is number 1 in online safety.One more thing it's noticeably faster than other browsers.You can also change the way it looks.I don't know if they have anything for Linex though. Thank You for choosing FixYa.
Sep 01, 2011 | pets4you.com Computers & Internet
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
A/c WOULD NOT WORK. TOOK TO A GARAGE AND THEY TOLD ME RELAY WAS BAD AND CHANGED IT OUT. aFTER THEY SAID IT WAS "FIXED", drove away and noticed radio did not work at all, no time display or...
Sounds like a case of selling a car, when the problems
become too stressfull & you bought it
Your shop tried but may not have been
in the upper 10% skill wise
Need the best place around & a
fresh start.
I think they had the battery disconnected
& ran out of knowledge when it can time to
give you the car back.
I won't even guess without the car to test
May 26, 2011 | Chrysler Concorde Cars & Trucks
I have a soniq b100 disc player, which only responds intermittently after only 6 months since purchase. The player won't turn on, the buttons on the main unit have stopped responding and the remote...
Sorry, no there isn't much you can do at a consumer level with this player, except, if you still have a manufacturer's warranty, taking advantage of it and sending the unit back for warranty repair/replacement (whichever they suggest to you). It is clearly malfunctioning, beyond user control - send it back as a warranty claim (if you still have one on this model). It won't cost you in repairs that way.
Don't put up with a defective product, send it back - get it fixed under warranty free of charge (if applicable), or the unit replaced (again, if under warranty, free).
It won't cost hundreds of dollars and shouldn't take forever to resolve this simple case. Good luck. This is something the manufacturer should worry about; not you.
May 06, 2011 | Televison & Video
GE WPGT9360E Profile Harmony 4.0 cu. ft. Washer with Stainless Steel Basket Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
