Question about Refrigerators
Does a maytag refrid. model # PBf1951HEQ have a reset botton?
Moved it and now won 't turn on
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: Maytag mtb2156ge refrig freezer not working..Refrid
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 07, 2011
Dryer won't start
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
Sep 03, 2012 | Maytag Dryers
I have pavilion dv7 won't turn on
First, To put the laptop to charge the battery for least 1 Hour, if continue won't Turn on , apply botton power and ESC and active the troubleshooting its possible that ypour battery is die,
Jun 21, 2012 | HP Computers & Internet
Maytag Dryer MDG6800AWW won't start, lights all on
There is no reset, There will be either a defective solder joint in the controller or the controller is faulty and needs replaced.
Mar 10, 2012 | Maytag Dryers
F21 code still flashes after i've unclogged line - reset?
if you cleaned out the pump by removing the center part of it and it still shows f21,either you didn't clear everything out of the pump,after you pull out the center piece stick your finger inside where the impellar is to see if you feel anything rapped around it,if it's clear and still won't drain then you need to buy a new pump and remove the old pump and install the new pump part number 280187 and it's around 120 dollars http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MFW9700SB1/3048/0153200/W0705107/00006?blt=06&prst=&shdMod=
Dec 10, 2011 | Maytag EPIC MFW9700S Front Load Washer
"Card Locked" message comes up periodically and
Switch of the camera and eject the memory card. carefully take a look @ d side of the memory, u'll find a botton with an indication of Lock and Unlock. Move the botton to the Unlock indication.return the memory card back into the camera carefully and dats all.
Oct 10, 2011 | Polaroid i633 Digital Camera
My dehumidifier full light is on but the unit is empty and the fan motor won't work. Is there a way to reset it? Is that why the fan motor won't work?
This is generally causes by improperly installing the water collection bucket after removing it to empty it. Or the float valve in the top ow the water bucket s stuck in the "UP" position. Some Maytag models have a float control that moves from left to right, depending on how much water you want it to collect, before having to empty it. It may be stuck in the center position and needs to be moved left or right.
When installing the bucket, be sure that it fits into the holder "squarely" from top to bottom and makes contact with the bucket removal safety switch at the back of the bucket holder. When installed properly, the bucket should not tilt down at the bottom.
Hope this helps you and thanks for choosing FixYa.
Aug 06, 2011 | Maytag Dehumidifiers
How do I adjust the pump belt on Maytag washer ?
Depends on model.
For top load units with two belts under botton panel, tilt empty washer against a wall to allow access to belts and loosen the 3 pump mounting screws. See page: http://www.applianceaid.com/maywash_belt.html
Jan 07, 2010 | Maytag Atlantis MAV5000
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
