Question about Gateway Media Center 610XL (610XLMDIA) PC Desktop
Monitor won't turn on?
The light is on in the back of the cpu, but the monitor wont turn on. No light on the switch.
    Scholar:
  • 88 Answers
I would double check you power connection to the monitor, if that's good. I would say that your monitor has gone bad on you. If it's still under warranty by chance take it back, if not you will need to get a replacement monitor.
I hope this helps,
Thanks for using FixYa,
Eric
Posted on Jan 24, 2009
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
I have an e-machine and when I turn it on all it does is blow air. It won't show up on the screen, the fan just keeps blowing! Any ideas?
Check the color of the power light on the monitor (screen). If it is orange, that means you're getting no signal from the CPU to the monitor. If that's the case, check the signal cable going from the CPU to the monitor to make sure it hasn't been disconnected.
Dec 14, 2012 | Computers & Internet
Machine wont boot
There is your answer no power to the monitor. Make sure it is plugged in replace with another monitor if you cannot get the button on the monitor to power on the unit. Maybe time for another monitor. John
Apr 20, 2012 | Dell XPS 210 PC Desktop
What do i do when my computer wont turn on at all and the screen says "NO SIGNAL"
Your CPU may not be getting power. You need to start there. verify the plug is plugged in to a known working recepticle - ie plug a lamp in or your monitor for that matter - exact same plug. Once sure, then verify your power supply switch has not been switched by accident. get a light and look physically at the back where the fan is. The switch is obvious - with a 0 or a 1 - the 1 needs to be pressed in. If the CPU still wont turn on, then the power supply is likely bad - especially if no beeps. If this is the case, you need to replace the power supply. I would take your cpu in to get checked as you may have blown your cpu completely and you dont want to buy anything for a dead motherboard.
Jun 13, 2011 | HP Pavilion 734n PC Desktop
Wont start up
Check physical connections first, check monitor cable if securely plugged in and then check power light of monitor. If power light on monitor is amber or yellow it means that monitor is not getting a signal from cpu/ tower. Try to do a power drain on the computer, remove power cable at the back of the computer and then press and hold the power button for 10 secs, after that plug in power cable again and restart the computer.Check if there is any connection if not then try to use another monitor, a known good one. If you get a video from another monitor it means monitor is already defective.
May 15, 2010 | HP Pavilion a1610n PC Desktop
Philips LX1000 not booting up
I need many more information
1) is their a power on the CPU. if yes lets check the monitor, uplug the monitor and turn only the monitor on, their should be some message on the monitor. If no error message on the monitor, possible monitor issue.
2) do you find any error message on the screen
2) If no light on the tower, do you find any light on the back.. please reply to this question
Dec 15, 2009 | Computers & Internet
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Monitor black with green light on
did you changed frequency of that monitor? if it is out of factory setting that could be the problem, try to connect it again as secondary and set Hz to default, if that does n't work try same settings on both monitors? i have connected two monitors i had same problems , my secondary monitor was clone for tv if you are using secondary monitor for clone to ty (with s-video or whateever) if tv is old it must be 60HZ 800x600...
Apr 27, 2009 | Computers & Internet
A mind of its own
check the cmos battery and the power suply. lok for swollen compassitors
Dec 30, 2007 | Computers & Internet
Emachines 1900+ gets power to the monitor and computer but wont boot
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Gateway Media Center 610XL (610XLMDIA) PC Desktop Logo
253 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
