Question about Garden
How do i install primer pump to weedtrimmer model#53677340000 missing cover to primer pump
I don't have owners manual for this craftsman weedtrimmer .I also need to know how to install this primer fuel line to fuel tank.
worldvet
  • 859 Answers
SOURCE: Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Posted on Oct 28, 2008
#1 Taper
  • 1040 Answers
SOURCE: need diagram on fuel lines on a 26 cc craftsman weed eater
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 16, 2009
#1 Taper
  • 1040 Answers
SOURCE: craftsman 28cc gas weedeater gas line connections
Jim
Posted on Jul 03, 2009
rycgl
  • 1545 Answers
SOURCE: Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Posted on Jun 01, 2010
hunter19_46m
  • 7482 Answers
SOURCE: 17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Posted on Sep 19, 2011
Schematic of carburator on Model No. 917.776740 Briggs and Stratton engine on a 675 Series on a Craftsman Wheeled Weedtrimmer.
remove the water from the fuel tank
\ put in about 2 table spoons of methylated spirits in to fresh fuel in the tank , use a primer bulb and pull several times to get the new fuel into the carby
The methylated spirits breaks the water down so that it goes through the jet
Jun 11, 2016 | Craftsman Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Craftsman trimmer #358798420- can't remember how to put fuel lines back on the carb & primer bulb.
Is this question for a mower or a trimmer? If for a mower there is only one fuel line. If it is for a trimmer, there are two fuel lines. One goes from the filter in the fuel tank to the carburator primary inlet. The other goes from the primer bulb to the tank and is the return line. GOOD LUCK.
Jul 26, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a Craftsman Weedwacker 25cc 358.791030 that won't start. Primer bulb is not getting gas. Gas line is connected to the filter resting at the bottom of the gas tank. The line for the primer bulb...
that line should be longer, it contains the filter which is the pick up, and should rest inside the tank fully,, see if its possible to pull that line farther into the tank, its not going to start until the primer bulb fills
Jul 24, 2011 | Craftsman Convertible 25cc. Gas Line...
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Need a diagram for installing new gas lines on craftsman weed eater model no.358.797101.I wanted to put new lines on but lost my train of thought.The hose ends were leaking due to age.
I don't have a diagram, but I can give you detailed instructions. Hopefully this will get your "train of thought" back on the right track.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
May 17, 2011 | Craftsman Garden
Need to know the fuel line routing including the primer bulb.
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Look carefully at the 2 nipples on the carb. You can tell one is slightly larger than the other. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. completing the purge circuit. This info pertains to the Craftsman 32cc with Zama carb and may work on the 25cc model as well.
Jun 01, 2010 | Craftsman 25cc Gas Line Trimmer
On my craftsman gas edger, the fuel tank has 2 holes on bottom, my fuel lines broke. i bought new lines but how do you install the lines do you put a fuel line in each hole or do you use tine same line and...
Hi ken If your machine has 2 holes in the tank it must have a primer first of all you you must fish out the pick up filter from the tank feed your new fuel line into one hole and out the filler hole connect the filter & put it back in that line goes to the bottom of the carby the next one from the top of the carby to the primer then from the primer back to the tank.
Jul 10, 2009 | Garden
Craftsman 28cc gas weedeater gas line connections
Jim
Jun 30, 2009 | Craftsman Garden
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
