Home | Graphic Tablets | Photoshop and WP5540 com...
Graphic Tablets
Problem for Graphic Tablets
Generic problem for all Graphic Tablets
Photoshop and WP5540 compatibility
By bouncy_hanyo on Jan 24, 2009
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Please help!
I have a two-year-old Manhattan brand WP5540 pen tablet. It’s not fancy at all, it was like $25. I had problems with it and tried reinstalling the drivers when I got Photoshop CS4. Well, the tablet is now working, but it is still having serious issues within Photoshop. I searched around thousands of help sites and followed numerous helpful hints including:
-Plugging the tablet into the USB on the back of my computer (This temporarily solved my problem of straight lines when I was drawing a curved line, but the problem came back.)
-Setting specific settings and restarting Photoshop (This works, but only for one stroke; after I draw the first line, the settings are once again screwed up.)
-Right-clicking the Photoshop icon, going to properties, then Compatibility and checking the box ‘Turn off advanced text services for this program’ (I have no idea what it did. I thought it helped, but it certainly didn’t solve my problem.)
The actual current problem is this:
After starting Photoshop, opening a file and setting my brush settings to ‘Pen Pressure’ (under Shape Dynamics-Size Jitter-Control), I can make one line exactly the way it should be, with me controlling the line thickness with my pen. After that first stroke, however, any attempts at drawing with the same settings produces marks so tiny and light that you cannot see them without zooming in about 700%. If I change any of the settings and change it back to pen pressure, it still makes unbelievably miniscule marks. (Photoshop is recognizing the attempt, though, because the layer I’m working on in the Layers palette flickers every time I make a mark. I originally thought that no marks were being made at all, until I zoomed in and tested it.) If I switch the Control to off, I have the problem that no matter how long, loopy and curvy I attempt to make my line, it simply makes a straight line from the point where I started my line to the point where I ended it. If I restart, the whole process starts over with the one single pressure sensitive line and the phooey to follow.
Something I just found out: The above was all done using a size 3 brush. After everything is screwy, if I change the brush size to, say, 15px, and press very hard with my pen, a (once again straight) stroke so small you can hardly see it is made. Pressing very hard with the pen and swiping it quickly across the tablet produces straight lines of varying widths. I guess it is still pressure sensitive, but what is with the eternally straight lines?
If I change the settings to Pen Pressure (under Shape Dynamics-Size Jitter-Control), click the little lock icon beside the Shape Dynamics option, close Photoshop and reopen it, open a new file and select a brush and draw a line, it works exactly how it should, for a time. The weirdest thing about my problem is that the results are random every time. I tried restarting Photoshop with the settings locked and tried the brush, and it was pressure sensitive for two strokes before shifting to the ‘straight, tiny line syndrome’. I tried this again and was able to make maybe fifty marks before everything went straight. I once again tried switching to a larger brush (32px) and all the lines were once again perfectly straight, and seemed to be responding in some way to the pressure sensitivity, but it was utterly random. Like, I would press really hard in a straight line and it would taper from a small tip to a large end. Then I tried swirling the pen around while still pressing hard on the pen I would get maybe a 1px wide straight line with no varying widths. I tried doing the same exact motions on the tablet with my pen and would get differing lines every time. Does my Photoshop have a bug? Could it perhaps be a bug not yet worked out of the new CS4 program? Or is it my tablet not being compatible?
The mouse always works when I try using brushes with it, but it doesn’t of course give me the tablet brush effect of sensitivity.
I have the driver that came on the installation disc with my tablet installed currently. I don’t know if that’s out of date, and if it is I don’t know how to get a current one.
What the heck is the matter? My last resort will be investing in a Wacom.
Same Problem
Apr 09, 2009
-   Same here, but with a Genus tablet (mousepen 5x4) -   Guest
Mar 31, 2009
-   I have the same problem: My graphic tablet Manhattan WP8060 works well in Photoshop CS3, but not in Photoshop CS4.
I have Windows XP SP3 and the drivers installed are "Tablet driver 412".-   tododua
Mar 31, 2009
-   I have the same problem: WP8060 works well with CS3, but not CS4...
Still couldnt fix it.-   Guest
Solution #1
posted on Jun 24, 2009
Somewhat Helpful)
Paperninja
Rank: Apprentice
Rating: 75%, 1 votes
get PS cs3, never had problems with that one, i own a genius 8X6 and it was perfect, yeah i know it sucks cause i brought cs4, but well, gotta wait till those guys from adobe fix that problem
Was this helpful?
Yes
No
Popular Solutions for Graphic Tablets
Questions and Unsolved Problems for Graphic Tablets
Answer
I am an education student and have to teach a lesson to my class. I created a lesson on the RM... (More)
Answer
Hi! I'm not sure if my tablet is the Wacom graphire, but it is a wacom tablet and is about 2yrs old.... (More)
Answer
har en emachine modell 5260 som er 4år s / N XIA5440002791, skjermkort ser ut til... (More)
Answer
can you buy the pen to the Gear Onteractive Pablo writing pad?
Answer
I lost my hanvon tablet installtion cd? Is there anyway I can install it without a disc?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Graphic Tablets:
Top Graphic Tablet Experts
Rank: Guru Guru
Solutions: 14780
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Graphic Tablet Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
