Servo move higher & lower error in solvent printer dgi vt II-92
Wen i start the printer the servo motor is runing 10 sec.and stopd and show the servo move higher & lower error.
  • kanakartstud
    kanakartstud Jan 18, 2013
    But Remove the motor &plug the 24 volt dc suply,motor is runing.
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Tip
Error Code Canon iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Error Code iR2200 / iR2800 / iR3300 / IR3100
Error Code
Detail
Code
Error Name/Explanation of Error
E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
The temperature of the fixing film is as follows:
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
E014
000
After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec.
E019
0000
The waste toner case is full of waste toner.
E032
0001
The DA unit connection is disconnected (after connection).
E051
0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
on Mar 14, 2010 | Office Equipment & Supplies
Tip
Error code CANON iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E000
0000
E001
0000
0001
0002
E002
0000
E003
0000
0001
E007
0000
E010
0000
on Dec 18, 2009 | Office Equipment & Supplies
Repair temp control for chev 92 s10 4.3
s10 not S10 blazer, they are diffr.
HVAC?
the temp control lever is bad (knob)
is it stuck? did you look to see if its cable. or vacuum or electric operated.
you can do everytime i do, im looking at alldata.com
and what do i see, so can you. if you want,
click HVAC>
the heater box shows. a damper controls the temp damper door.
so one looks at that lever, and see if it works as you move the dash lever, if it dont move, its stuck or the acuator is bad.
on this car its vacuum or cable. acutated. (no motors)
so just look, does the damper have a vacuum servo?
if not its cable.
if the cable is bad its obvious right? one end moves and other dont?
mech 101?
or if vacuum ?
you apply hand vac tool to vac. servo (yes hose removed)
and does the damper move now? y/n
it not it jammed or the vacuum servo s bad. move damper by hand.
does it move, y/n, no , its jammed, solution is obvious i hope.
yes moves
do a leak down test on the vacuum servo (a classic test)
fails its bad, passes for 30seonds, its good. and most move.
that ends the damper side
if the servo works then the vacuum from the control head is bad.
bad hose. cracked hose or bad head. or no vacuum to the head.
my only does not show which lever is vacuum and cable
only that there are both.
but that dont matter any mech, he looks first.
ah ,just the cable fell off, end story.
Jun 19, 2014 | 1992 Chevrolet S-10
How do i solve servo motor high error in solvent printer
Please follow the steps below to hard reset the printer and let me know the result.
1.Remove all the cables from the printer.
2.Wait for 10 mins.
3.Connect only the power cord and try to power on the printer.
4.If the problem is solved, then connect all other cables, otherwise let me know.
Aug 28, 2012 | Office Equipment & Supplies
Tip
Detail
Code
E000
0000
E001
0000
0001
0002
E002
0000
E003
0000
0001
E007
0000
E010
0000
E014
000
E019
0000
E032
0001
E051
0000
E064
0000
The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
on Dec 08, 2009 | Office Equipment & Supplies
What is the error 42:10? I keep getting this error and sometimes error 86:01, please help. When I start plotting a map or in this case early this morning on my first map I got this error 42:10, so I turned...
42:10 is carriage motor error, 86:01 is carriage jam. Check slider rods (both upper and lower) and carriage oil pads are lubricated, clean encoder strip. Is your printer is shaking too much? Place it firmly.
Feb 08, 2011 | HP Designjet Z6100 InkJet Printer
Canon IR 2200 manual
Некоторые ошибки зависят от того, какая опция установлена: например, ошибки E514 для Saddle Finisher-G1 и Finisher-J1 имеют разные причины.
Код ошибки Субкод Описание E000 0000 The reading of the main thermistor does not reach 30oC 1 sec after the main power switch is turned on. Or, it does not reach 70oC 2 sec thereafter E001 0000 The main thermistor detects 250oC or higher 0001 The main thermistor or the sub thermistor detects overheating (hardware circuit detection) 0002 The sub thermistor detects about 295oC or higher E002 0000 The temperature of the fixing film is as follows:
  • has exceeded 100oC, but does not reach 115oC within 1 sec thereafter.
  • has exceeded 140oC, but does not reach 150oC within 1 sec thereafter.
  • has exceeded 160oC, but does not reach 165oC within 1 sec thereafter
  • E003 0000 The main thermistor reading is lower than 140oC when paper is moved 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 An error in the rotation of the fixing film is detected.
    The reading of the main thermistor is 100oC or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven E010 0000 After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec
    Sep 13, 2009 | Office Equipment & Supplies
    256 people viewed this question
    jasbo
    jasbo
