Question about Home Security
Carbon monicide detector 3 short beeps
Emitting 3 shot beeps every minute
SOURCE: smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Posted on Jul 17, 2008
  • 5 Answers
SOURCE: carbon monoxide detector err code
You are going to hate this as much as I did!
In the manual you will read this ..
Manual for Kidde Nighthawk C02 Detector
On page 13
Unit Malfunction
In the rare event that your alarm malfunctions,
it will alert you with a short “chirp” and the red
LED will flash once every 30 seconds. The
digital model will display “Err” as shown in
Fig. 6.
Seven years after initial power up, this unit will "chirp" every
30 seconds to indicate that it is time to replace the alarm.
The unit will not detect CO in this condition. Please replace
immediately.
Posted on Dec 14, 2008
  • 603 Answers
SOURCE: Our carbon monoxide detector keeps beeping every
Need new detector
Posted on Dec 29, 2009
getyourfix
  • 43 Answers
SOURCE: My nighthawk Kidde carbon monoxide detector keeps
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
Posted on Jul 27, 2010
  • 1082 Answers
SOURCE: our kidde battery operated Carbon Monoxide
Relocate it to an area of fresh air - outside will work.. Does it still beep?
If yes, recover the new battery and toss the unit.
Do you have it located in a steamy damp area? Laundry room, bath room etc.. That will cause it to malfunction too..
Posted on Dec 03, 2010
It is emitting continuous shriek does that mean carbon monoxide leak?
What are you asking about? IF this is a carbon monoxide detector then that would be the case.
Feb 12, 2016 | Home Security
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
My carbon monoxide detector just has one sold beep and is not plugged in.
I assume you mean your carbon monoxide detector has one solid beep, and it is probably an AC unit. It may be safe to assume that it has battery backup if it is beeping without being plugged in.
First, you may replace the battery with a new one, plug it in and hit the reset button. If that doesn't work, you could bring it in to your local fire department to have it tested.
Check the expiry date on the Carbon Monoxide Detector. It should be replaced if it is more than 5 to 7 years old, check manufacturer recommendations.
A replacement carbon monoxide detector will give you the protection you need and peace of mind. Your safety depends on how fast you deal with this issue.
Jul 07, 2010 | Kidde Nighthawk Combo Gas/co Detector
How can I shut off my Kidde carbon monoxide detector when beeping
Here is the link to the manual for your Kidde model KN-COB-LCB-A
Carbon Monoxide Detector. This may help you solve your issue.
You may find more related information on my website. If you need a replacement or you need to add additional Carbon Monoxide Detectors in other levels of your house, you can purchase them here.
This issue should be solved immediately, Carbon Monoxide Poisoning can only be avoided by making sure you have good working CO Detectors in your house, camp or recreational vehicle.
Jul 24, 2010 | Kidde Nighthawk Combo Gas/co Detector
My nighthawk Kidde carbon monoxide detector keeps beeping every 25-30 seconds. Do I need to buy a new one?
Jun 27, 2010 | Kidde Nighthawk Combo Gas/co Detector
How to fix detector
You don't mention how old the detector is. If it is more than 5 years old the detector may be beeping to indicate the end of its service life. A smoke detector can last much longer but carbon monoxide detectors have a limited life span. If putting in new batteries doesn't fix the problem then most likely you will need to replace it.
May 31, 2010 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
Periodically emits 3 loud beeps. Displays 888.
The CO detectors require replacement of the battery periodically.
Unlike smoke detectors, the detector element itself also requires replacement as well as the battery and is sold as a module with the battery attached.
May 02, 2010 | Kidde Nighthawk Combo Gas/co Detector
British gas carbon monoxide detector problem
If it is beeping 3 beeps every minute it is at the end of its battery life you can just replace the batteries by prising the cover off carefully.be aware though that the life span guarantee of these is only 5 years.
Dec 13, 2009 | Kitchen Appliances - Others
Carbon Monoxide wired to the house, no battery, beeping
the batt is used for backup. Its beeping to get you to install a batt
Jun 18, 2009 | First Alert SA302 Dual System Smoke...
Smoke alarm/carbon monoxide detector
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
Home Security Logo
15 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
