Question about Kodak EasyShare C330 Digital Camera
I keep getting lens error 12 and 22 on my camera kodack CD33
  • Kodak Master
  • 4,738 Answers
Posted on Jan 16, 2013
SOURCE:
SOURCE: Lens will not retract
I had exactly the same problem and I went to this site and got my solution. I banged the bottom of the camera with my palm and turned it off and on at the same time. On about the fourth bang the lens retracted and cleared the error codes. I know, "Caveman Maintenence" but it worked. Can't hurt to try...
Posted on Aug 31, 2007
mads_aye
  • 58 Answers
SOURCE: lens error
hello
it may be a bug or caused by impact damage, even the technical support team doesn't have the meaning of that error code but for troubleshooting you can call 1 800 235 6325 opt. 12 or go to www.kodak.com/go/itg
a repair may also be arranged for you - through phone call or the website
Posted on Feb 13, 2008
sandipmistry
  • 57 Answers
SOURCE: lens problems
there is a problem wit your lens section, get it repaired with your company professionals. Your camera may be fallen or being pressed from front side by someone. The new ZOOM will give the same best result and no further problems.
Posted on Apr 24, 2009
leepania
  • 1099 Answers
SOURCE: after a fall my Kodak cd33 shutter doesnt open,
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 03, 2009
Testimonial: "thanks for the helpful info! "
  • 102366 Answers
SOURCE: LENS ERROR 12 ON KODAK EASY SHARE CD33
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
When i turn on camera i get message lens error 25
According to the symptom you have to replace the optical lens assymbly. Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Additionally, here is a video of the normal power up sequence of the camera and there other moethods:
1. Here is the first alternate method
2. Here is the second alternate method
Good luck.
Jun 07, 2011 | Kodak EasyShare CD33 Digital Camera
Our camera fell in water for about one minute with the camera on. now it will not work. will it ever work again? i was able to save the memory care with alot of pictures on it tho.
If you tried to turn it on while water was inside, you may have fried the circuits. You can try to dry it out by burying it in a bowl of dry rice for one week. Then try to turn it on and keep your fingers crossed. Even if it works, there may be a film over the lens elements inside the lens tube. Good luck.
Sep 18, 2010 | Kodak EasyShare CD33 Digital Camera
After a fall my Kodak cd33 shutter doesnt open, and it says on screen 'lens error 22'. can you help?
Contact KODAK:
Nov 28, 2009 | Kodak EasyShare CD33 Digital Camera
Lens error:22
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 12, 2009 | Kodak EasyShare CD33 Digital Camera
Lens error: 22
Dec 29, 2008 | Kodak Easyshare M753 Digital Camera
Dec 10, 2006 | Kodak EasyShare CD33 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
57 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
