Question about Texas Instruments TI-83 Plus Calculator
Conversion a rentangualr buliding lot is 100 ft by 150 ft. determine the area of this lot in square meters? (i want step by step so i can know what is going on)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
One foot is 0.3048 meters. One square foot is 0.3048^2 meters = 0,9290304m^2. Multiply that by the area in square feet which is 100ft*150ft = 15000 ft^2.
The result is 1393.5456m^2
Posted on Jan 17, 2010
If my room is 14 x12 ft how do i know how many square meters it is?
First, you want to find out the square footage of the room. You do that by multiplying length times width. In your case, 14 x 12 feet would equal 168 sq/ft. Next, you multiply square feet by square meters with 1 sq/ft equaling 0.0929 sq/m. So, 168 times 0.0929 would equal 15.6072. If you google a conversion calculator for square feet to square meter , it will give you 15.6077. In other words, your room is just over 15 and 1/2 square meters. Hope this helped
Aug 10, 2016 | Building Materials
How to convert room measurement to square feet?
Measure the room in feet, multiply the two together.
12 feet a 8 feet room ? 12x8 = 96 square feet.
Or conversion? See below
Square Feet to Square Meters conversion
Dec 02, 2015 | Carpet Pro Vacuums
Conversion square meter to hectere
One hectare is 10,000 square meters (100 meters by 100 meters).
Jun 05, 2014 | Optics
Centimeters to meters
There are one hundred (100) centimeters in a meter, so there are 10,000 square centimeters in a square meter.
Jan 21, 2014 | Computers & Internet
Hi i need to know how to convert 80 sq ft to cubic meters
You don't. Square feet is a measure of area while cubic meters is a measure of volume.
Consider a room 8 ft by 10 ft. The floor area is 80 square ft. What's the volume of the room in cubic feet (let's not worry about converting to meters yet). Well, that depends on the height of the ceiling, doesn't it? If the ceiling is 8 ft high then the volume is 640 cubic feet. If the ceiling is 12 ft high then the volume is 960 cubic feet. Without that third dimension, you can't calculate the volume.
Oct 18, 2013 | Office Equipment & Supplies
Square feet converted to square metres
Simply square the conversion factor between feet and metres to get the conversion factor between square feet and square metres.
One foot is 0.3048 metres, so squaring that gives one square foot is 0.09290304 square metres.
Aug 20, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
What's the conversion formula for sq. ft. to sq. meters?
The square foot is the smaller unit of area, so you will have to divide a measurement in square feet by the number of square feet per square meter. Since there are 10.76 square feet per square meter, divide by that value.
Obviously, to convert from square meters to square feet, you would multiply by that value.
1 square meter is 10.76391 square feet.
Feb 13, 2011 | Garden
I have a lot tha is 152.95' X 119.88' X 130.00' X 50.00'. What part of an acre is this.
  1. This lot does not have the form or a regular quadrilateral (rectangle, square, parallelogram, etc.)
  2. So you cannot calculate its area, you have to know exactly the shape it has.
  3. With polygons, one usually cuts them into triangles.
  4. You have to cut it into two triangles,
  5. measure the base and the height of each triangle,
  6. use the area formula for the triangle ( area = heightX base/2)
  7. After you calculate the areas of both triangles, you add them to get the area of the the whole lot in ft^2.
  8. Using the conversion formula between acres and ft^2 which is 1 acre=43560 ft^2, you divide the area of the lot in square feet by the number 43560 ft^2 and express the result as a percentage or a fraction .
Hope it helps.
Thanks for using FixYa.
Nov 19, 2009 | Calculated Industries Pocket Real Estate...
Texas Instruments TI-83 Plus Calculator Logo
122 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
