Question about Samsung LE32B450 32 in. LCD TV
/The tv makes a banging and crackling noise when switched on and it turns itself off and on for about five minutes before it works.
    Top Expert:
  • Samsung Master
  • 74,383 Answers
It sounds that the backlight inverter board has damaged. Check and replace it.
Posted on Jan 16, 2013
3 Suggested Answers
SOURCE: when i turn the tv on it doesnt come on straight away
I found a fix for this problem on another forum, It's caused by some blown capacitors on the main power board. I have a link to the original post, with step by step pictures for replacing the blown capacitors but don't know if it's ok to post it here. The repair cost me £7.49 for 5 capacitors RS part number 526-1109 and about £4.50 of that was for next day postage. I did the job myself in about 15 minutes and I have no experience with a soldering iron (i even had to borrow one). I replaced 3 capacitors, 2 of which looked blown and one which just looked swollen.
Remove the back off your tv, and just take a look at the small array of capacitors near the top right corner of the centrally situated power board. there are 4 identical capacitors rated at 1000uf 10v 105 degrees C. I think the silver capacitor lids should be flat or even slightly concave. The ones I replaced were all slightly convex and 2 of them had a tiny amount of what looked like brown corrosion right in the centre of the caps.
For a few quid I'm sure you could get someone else to do the soldering if you lack confidence.
The original post also linked to a supplier of the main power board for £130. I didn't mind having a go myself because I figured if I fouled up I could always just buy the board
Posted on Apr 15, 2009
toolkits
  • 1099 Answers
SOURCE: i have a sumsung 50
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Jun 14, 2010
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
Tv turned itself off and will not turn back on
when pushing power switch the green light turns on with a crackling noise and goes back to sleep mode wont turn on
Feb 22, 2011 | Pioneer PRO-620HD 58" Rear Projection...
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a beomaster 2200 and the sound will only come from one speaker, I have checked the speakers and these are ok. When I move the balance control I get a loud crackle noise. Many Thanks John Bailey
if the loud crackle noise is in the speaker that doesnt work you may have a problem with the balance control itself or int. contacts in the switchbank.clean and lube both for starters.
Oct 17, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
The tv takes 25 minutes to turn on. it shows no signal, makes loud crackling noises and then turns on
i would look at the power supply as it sounds like the caps in it are getting weak
Oct 14, 2009 | LG Z37LC6D 37 in. HDTV LCD TV
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
I have a 42 inch phillips model 42pfl7662d 1080dp lcd tv. today it started making crackling noises at the rear right hand side, then it automatically switches itself off, and then on again after a minute...
sound s like the HV generator (flyback) This is repairable with a new flyback if that is indeed whats happening. Take the back off and dont touch anything but try powering up the set and see if the noise is coming from a part that looks like this with 4533b6a8.jpg big red wire coming from
Mar 30, 2008 | Televison & Video
Samsung LE32B450 32 in. LCD TV Logo
164 people viewed this question
Henry  Thomas
Henry Thomas
