Question about Marshall Music
Fuse rating of marshall tsl amp - Marshall Music
4 Suggested Answers
  • 5603 Answers
SOURCE: JCM 2000 TSL 601 MARSHALL AMP TURNS ON NO SOUND TUBES DONT LIGHT
If the tubes are not lighting, either the fuse has blown or the power transformer might have an issue.
Be vvery careful as there are lethal voltages present in these.
If the fuse blew, replace it and try just once as there could be other problems and more damage could be done.
Posted on Sep 30, 2009
  • 5603 Answers
SOURCE: What is the fuse rating for a Marshall MG30dfx?
According to the schematic, the fuse for 120 volt is a 1 amp.
This is a reasonable size for this size amp.
Posted on May 14, 2010
  • 5603 Answers
SOURCE: the valves on my Marshall TSL 122 are getting to
Probably the bias is set wrong... Please note that when installing MATCHED pair tubes, the tube pairs usually go at opposite ends of the strings, that is one on either side of the center of a set of four.
Posted on Jul 23, 2010
Marshall jcm2000 tsl combo turns on but no sound from any channel
Make sure speaker cable works and is connected then check fuses. If it has a master volume, make sure it's turned up.
Sep 04, 2014 | Marshall Amplification Music
Where is the fuse located in a marshall ma100 h amp head
The fuse should be located on the back panel near the power cord. However, there are also internal fuses as well....If the amp is vacuum tube you will also have a HT fuse as wall as a power fuse. If it is a solid state unit then it will have a power fuse.. Hope this helps.....If you need more info let me know....
Jan 16, 2014 | Marshall Amplification Marshall MA100H and...
On the Marshall 5 button footswitch for the TSL, there are 7 wires in the cable, 6 of which are clearly labeled by color on the circuit board in the footswitch. The brown must be combined with another wire...
Only 6 wires are used by the amp. Tie the brown wire to the metal frame to act as shielding if anything. You will probably find that the brown wire either connects to the shell of the connector or to nothing.
Apr 23, 2011 | Marshall Amplification Marshall 5-Button...
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
Dec 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
The valves on my Marshall TSL 122 are getting to hot.What might be the problem? Can you get me the scheme for that amp?
Jul 23, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
May 13, 2010 | Marshall Music
Fuse - 2amp for a Silvertone 1472 Amplifier
Hello endaya try www.digikey.com if you are using a 2amp buss fuse, its available, 117V is applicable to 220V, just follow the amp rating.
Apr 22, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Sep 29, 2009 | Marshall Music
Is there a circuit breaker
There should be a fuse holder near the place in the back of the amp where the power cord plugs in. Also some Marshalls have fuses in fuse holders on the circuit board. Always replace with the same value and type as the original fuse. Never open up the amp when it is plugged in to the outlet. When replacing the internal fuses do not touch the capacitors as they retain a lethal charge. If the fuse continually blows it is an indication of a more serious problem which will require servicing by a qualified repair person.
Jun 25, 2009 | Marshall Amplification Marshall MG250DFX...
Music Logo
23 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
