Question about Kettler Exercise & Fitness
Problem with Treadmill Kettler Track Performance. On display is ERROR 91. What does it mean? How I can fix the problem ?
Hello ! I have a problem with my Treadmill Kettler Track Performance. On display is ERROR 91. What does it mean? How I can fix the problem ? Best regards, Michael.
  • 3 Answers
SOURCE: Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
Posted on Aug 30, 2009
SOURCE: I have a quinton club track treadmill that posts an E203 error
E203 = Motor unable to run. Usually caused by the VSD Lower Board. This board is about 14" square on a Quinton Clubtrack Hyperdrive 3.0
Rather difficult to remove escpecially if your not familair with electronical compnents in a tight space.
My reapir coast $374 from J&R Technical Services and exactly one year later I got the exact same code. Warranty is 90 days.
It appears they rebuilt one of the components on the board called a Phase Modulator. There are three of them. They stated they had replaced it, but upon close inspection it appears that simply replaced the bad micro-component on the modulator and reinstalled the exact same phase again.
I'm debating whether to trust them once again. Little choice though since they control the market and have the equipment to reset the board upon repair. Nobody at thome has this equipment.
Posted on Nov 24, 2009
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
SOURCE: Kettler Treadmill TX 3 gives
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
Posted on Jul 03, 2012
ercupa190
  • 12223 Answers
SOURCE: Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Posted on Nov 28, 2012
I have kettler pacer treadmill it is not getting start,when I press start button the display shows system fault and also shows error dc6
Motor controller...these are typically motors that have speed controllers. When they fail, just test and replace. Call the manufacturer for parts.
Nov 25, 2014 | Kettler treadmill Pacer
Error code e11 I have kettler track motion , treadmill stopped working what do I do
Reset the treadmills, disconnect the power for 30 seg. or reset the small switch to the side of power button. and try again.
However you must RUN the software calibration for e11. and fix it
go to the HOOD cover motor, and follow the steps .
God bless you
Sep 30, 2013 | Exercise & Fitness
Error 51 Treadmill Kettler Track Performance
this a problem with the elevation motor. You are working with the treadmill without put in level.
You need LUBE the gear+shaft see the picture. But most importante adjust the POTENTIOMETER a little see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
High speed and error 91 and treadmill stop
Please recalibrate the machine with software calibration, for easy diagnose, troubleshooting and fix it
If the problem persist, you must need some basic parts or need service for repair. See hte block diagram attached.
God bless you
Jan 07, 2013 | Kettler TX1 Treadmill with FREE INSIDE...
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
ERR on the treadmill when I switch on. how do I fix and get working
Any other codes displayed? Safety key fit firmly in? Go to the front of the treadmill turn off the power switch off and unplugg the unit for at least 30 seconds then plug in the unit turn power switch back on. If this does not clear the error code your unit will most likely need to be serviced.
Nov 16, 2011 | Kettler TX3 Folding Treadmill
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please...
Apr 05, 2011 | Kettler TX3 Folding Treadmill
Hi Rendra,
Try this:
May 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
969 people viewed this question
Top Kettler Exercise & Fitness Experts
ray gallant
Steven Brandon
Steven Brandon
todd
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
