ROPER TOP LOAD WASH MACHINE RAB4232 WILL NOT GET RID OF DIRTY WAT
It will wash but it will not get rid of the dirty water, makes a grinding sound
  • 15,935 Answers
If you experience a problem where the washer does not drain and the drain pump does not run at all, here’s the information you need to replace the drain pump:
Symptom: PUMP IS NOT RUNNING, NOT DRAINING AT ALL.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. Sometimes objects get caught in the pump impeller and stop it from running. We’re going to assume that you have already done this and that the pump no longer runs. It is strongly recommended that you remove all residual water from the wash tub & drain line at this point or you will have about a gallon or so inside your washer and on the floor to clean up.
5. HINT: Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
7. Locate the electrical connection to the pump and disconnect.
8. Now locate the two drain lines and remove them. The hose clamps can be released by squeezing with a pair of pliers. NOTE: I would not recommend removing the hose from the bottom of the wash tub unless you really have to. This one can be difficult at times to get back on.
9. Remove the torx type screw at the front center of the pump and it should slide right out of the mounting grooves on the bottom of the washer case.
10. Your new pump comes with several adapters to place on the feet of the pump in order for it to properly fit your washer. These are rubber bushings that help get rid of vibration and noise. If you become confused, there should be installation instructions that come with your new pump. You can also look at the pump you just removed to see how the bushings are mounted.
11. Reinstall the drain lines to the pump. HINT: It is much easier to do this with the pump still OUT, rather than installing it. When you squeeze the clamps to open them up, make sure you slide the clamp completely over the hose AND the inlet/outlet tubes on the pump housing in order to get a good seal.
12. Reinstall pump by sliding the feet of the pump into the mounting grooves on the bottom of the washer case. Tighten the center screw and reattach the electrical connection.
13. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
14. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
15. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump is supposed to energize and begin to drain.
16. If the pump works normal and there are no leaks detected, reinstall panel and tighten screws.
CAUTION: Use care when reaching inside the washer case not to damage the small wire harness that runs along the front of the machine.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
NOTE: My initial symptoms describe a drain pump that is NOT running. It is actually possible for the drain pump to be running and STILL not drain. If the pump impeller becomes damaged, or if the motor shaft is stripped, the pump will run, but will not drain properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I just moved in a house with an old top loader washer After the water fills in and it starts to wash I get all these dirty particles What is that and how do I get rid of it
The dirty particles could be old soap dried in bottom. You could try putting white vinegar in soap dispenser and running on a pure cycle or if your does not have pure heavy cycle so it can break up the old soap. Unless you have well water and that can be caused by needing to add stuff to well for purifying the water.
Apr 20, 2014 | Washing Machines
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Bad smell in washing machine...clothes smell bad after wash
hi there is a build up of lime and old dirt in the inside of your drum the best thing to get rid of the smell is put a very small amount of bleach in the drum and put your machine on a very hot wash it will help in your hand book it will tell you to use your hot wash with a bit of powder and no cloths at leased once a month i dont know if you use your hottest wash most people dont these days because of the low temp powders, also the best product to use is lim away but you can only get it on usa bases or from the usa you might find someone on line that sells it that will get rid of all the lime thats been built up in your machine if you cant just use a bit of thick bleach hope this was helpful
Nov 18, 2011 | LG WM-2277HW Front Load Washer
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
My (gallery) front load is making my load dirty after the wash. I noticed that if I wash in cold water is not as bad as when I wash with warm/hot water.
Sounds like deposits or dirt coming from hot water tank or line running to washer.Turn off water supplies to washer and remove the hoses from the back to see if the filters/strainers in each port are dirty.If not add a little CLR to the washer and let it run a cycle.Hope this helps.Wouldnt hurt to check the drain strainer either on the bottom of the wassher if you remove the little access panel, might be something in there making water dirty
Jan 20, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Grease build up
I would run a small load with maybe a couple of dirty towels with some dish cleaning soap, particularly one with good grease removing capabilities. Also, be sure to use the hottest water setting you have available for this load.
Jul 10, 2010 | Samsung Washing Machines
Dishwasher smells after completed load. The water left on top of cups etc is dirty.
your machine is likely not getting rid of all the dirty water after the wash cycle. you need to make sure there is no debris left in any filters in the bottom of the machine and see if there is a part called a check valve somewhere, it may need to be replaced.
Oct 16, 2009 | Kenmore Dishwashers
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Problem with whirlpool front loader
Your water mixing valve is letting water in the machine between cycles. That is the valve that the hot and cold water hoses connect to in the back. Replace that valve to stop the water build up. Run a periodic cleaning cycle with a generous amount of white vinegar to rid the smell. Or you can buy a prduct called Affresh from a hardware store.
Jun 21, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
