Question about Saniflo & Saniplus& Macerator Pump
Opening a saniflow unit - Saniflo & Saniplus& Macerator Pump
  • 41 Answers
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will definately help.
Posted on Feb 07, 2013
Local authority state saniflow may choke at rainwater trap and will not accept saniflow going into rainwater drain
Your description sounds like plumbing from before bacteria was discovered. The output from a Saniflo macerator should be sent to a foul drain or cesspit and not a rainwater drain.
Some authorities allow local rainwater runoff into foul drains but this situation is gradually being designed out.
Could be your Saniflo installation didn't meet building regulations when it was installed. The fact it has been working fine for 2 years doesn't count for anything if it doesn't.
Feb 03, 2018 | Saniflo Plumbing
Leaking macerator unit
Shut off water supply and check where the leak is. Loosen the joint , reconnect it securely and reclamp. Before reclamping spray Stop Leak around the joint. Slowly open water supply. Goodluck.
May 30, 2013 | Home
Saniflow runs, but not straight after flushing
Jan 30, 2013 | Saniflo Home
Pump randomly runs
This problem maybe caused by a slight weep of water from the cistern the saniflow has a sensitive float system , once level is reached the unit will turn on until required level is acheaved again . So check toilet bowl to see if the is a trickle of water if so you need to take a look at the flush system in your cistern.
Nov 17, 2012 | Saniflo & Saniplus& Macerator Pump
Saniflow macerator
Depending on the pump model it can be that the float switch (membrane) might be warped or solids could be build up at the bottom which dont allow it to shut off. You wil have to open up the unit, remove the motor with pressure chamber and inspect it.;
Aug 02, 2012 | Saniflo & Saniplus& Macerator Pump
My saniflow dosnt allways come on when you flush
That can be a problem with the pressure chamber, the membrane might be warped or the micro switch may be defective. Open the lid and remove the motor and presure chamber. Inspect the unit for damages or any broken pieces. Check that the membrane is not warped. This can be tested manually by placing the motor on a work bench and putting pressure on the membrane to manually start the pump on and off. If parts are needed you can buy them through Saniflo directly. Their website is www.saniflo.com
Jul 13, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Saniflow plus works allright for w.c but will not work for shower
Thanks for the clarification - This rules out power supply to the unit, motors/pump and points more towards why the water would be pumped from the WC flush and not the basins ...
1. The Saniflo range of macerators have a pressure switch that engages when the water pressure inside the unit activates a microswitch that is encased in a waterproof container. It is possible that the water pressure from the shower and basins is not great enough to activate the internal switch.
So, I would propose two checks
a) If the unit previously worked for the shower and basins something has changed and it is most likely to be gunk inside the unit causing the switch to be less sensitive and only activate on the high pressure that the WC would provide. The fix would be to open up the unit and clean it - please let me know if you need info on how to do this
b) If this is a new install and the shower and basins never worked, you should check the fall in the pipework into the Saniflo is sufficient (should be 1 in 70 from memory - full install instructions are available from the Saniflo website)
c) It could be that if the unit has been in for a long time with a large number of operations that the microswitch is starting to fail and is not as sensitive as it once was (quite unlikely) - but always a possibility!
Replacement microswitches are freely available online and you should also be able to get the exact match spares from Saniflo
If this helps please leave feedback - if not please let me know and I'll try and help some more!
Good Luck :)
Feb 05, 2010 | Saniflo Sanibest Grinder Pump Only 013
How can you tell if the waste pipe is blocked on a saniflow toile
Yes the bowl will be slow to empty. Try squeezing the white discharge hose as the unit operates, if there is a blockage then this hose will be hard to squeeze. If hose is soft then blockage could be in the toilet pan U-bend in which case fill bowl with very hot water and leave to soften the toilet paper.
Jan 11, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
The saniflow unit is only 4 months old at first it was ok now it has started making a loud grinding noise when anything is done,toilet,sink or shower
There is no nice way to say it. You are going to heve to open it up and look in it to find what's stuck in the macerator mechanism.
Oct 16, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Why does my saniflow continuously come on even
could be a part blockage alowing water to filter back never put paper or towles in it
Sep 28, 2009 | Plumbing
Saniflo & Saniplus& Macerator Pump  Logo
130 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
