Question about Sewing Machines
Inlet filter blown capacitor on a bernette 330 sewing machine
The capacitor has blown so that the vaues aren't readable. If anyone can help I need F and Volts please
RickE1
  • 202 Answers
SOURCE: Bernette 65 Sewing machine
As a Bernina tech I may be a bit biased on this but I can say this... If you decide on this machine be sure you get it from a dealership with an on-site technician. Any can be an Authorized dealer but not many have a Certified technician. Not to say that you will need one but if it does get an issue in can be taken care of promptly. Also Bernina dealerships are required to have a class for you on their machines. I have worked for a Bernina dealership for the past 5 years and have not had a Bernette come in for a repair. Of the reviews I've read the complaints are of the tension which seems most likely a user default such as not keeping it clean after use, using cheap thread, not understanding how to adjust it for different fabrics, the right type of needle, etc.
I like the 1 step buttonholer and the threader. I wish the lighting was better.
If your going to spend less than 200.00 on a new machine you could do much worse. If you decide to not do the Bernette consider the Janome line next. (with an on-site tech)
Good luck.
Posted on Aug 19, 2008
  • 19 Answers
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Posted on Dec 10, 2008
  • 2692 Answers
SOURCE: Need Dressmaker 300z sewing machine manual
you're welcome. have a good new year.
Posted on Jan 01, 2009
bargainbox
  • 1388 Answers
SOURCE: Please walk me thru winding the bobbin on a
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on Sep 04, 2009
  • 19 Answers
SOURCE: manual for Janome Harmony 2049 sewing machine
www.janomestuff.com answer it all
Posted on Sep 16, 2009
How does one thread a Bernette 320? I bought a very old one with the stitch settings all 3 on the front of the machine
Perhaps this will help:
Bernina Bernette 320 330 Owner Manual
Just an additional hint, ALWAYS RAISE the presser foot when threading the top thread. This releases the tension disk allowing the thread to seat completely.
Mar 19, 2017 | Sewing Machines
I am need a manual for this machine please Bernina Deco 330
A pdf of the manual is available at-
http://www.bernina.com/en-GB/Support-GB/Machines/bernette/bernette-deco
Apr 09, 2016 | Sewing Machines
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
How to insert bobbin in a bernette 680 sewing machine?
Try going to this link and download the manual for either the Bernette 410 or 715 and look at the directions for threading and inserting the bobbin:
Bernina may not have a manual for your particular model, but these models may be close enough that you can still use the directions for your machine.
Jul 07, 2014 | Bernina BERNETTE 65 Mechanical Sewing...
Deco will not pick up bottom threat
change needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint
if these suggestions don't help then the sewing machine needs the
timing checked at a sewing machine shop
Oct 03, 2012 | Bernina Bernette Deco 600
My Bernette 65 sewing machine isn't pulling my main thread through. Bobbin tread is being pulled fine. What could the problem be?
Make sure you have a new needle in first and the correct way round, failing that the machine may need retiming
Sep 19, 2011 | Bernina BERNETTE 65 Mechanical Sewing...
Carriage on deco 330
I had the same problem with my bernina deco 500. Fortunately I could solve the problem, I have posted my solution please read it, it might help.
good luck.
Amany
Jul 04, 2009 | Bernina Bernette Deco 600
Bernina Embroidry Machine - MODEL Deco 330 (not 600) - Hoop arm (that attaches hoop to machine seems to be loose or worn.
are you taking about the part on the machine or the hoop itself? When was the last service? (should be at least once a year)
Jun 21, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
16 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
