Question about HP Photosmart C6380 All-In-One InkJet Printer
Photosmart 6380 making worrying knocking noise!
I can't print. I have reset the printer and have checked all print heads, cartridges, paper trays etc and still I have a loud knocking noise coming from inside the printer when I turn it on. After considerable printer preparation and lots more knocking I get "General Printer Error 0x61011beb" and the "Print Photos" button and "OK" button flash on and off. My HP solution center says "There is a problem with the printer. Refer to printer documentation. Press OK to continue." What does "Refer to printer documentation" mean?! I've looked through all the manuals online and can't find any clues. Any ideas, anyone? (P.S. yes, it's out of warranty . . . )
  • spot_onmarke
    spot_onmarke Jan 18, 2013
    I don't think this is a carriage jam, as when I open the top of the printer the carriage moves freely. Also, I was able to print a test page and if the carriage wasn't moving that would not have happened.
5 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Try to print but: get General Printer error 0x61000f6
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Posted on Jun 22, 2010
Testimonial: "Thank you very much for the information. very helpful. I am sure this information will help other people as well. Thanks again. "
  • 685 Answers
SOURCE: my hp psc 1350 printer will not print. when i turn
This should help.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00095908&cc=us&lc=en&dlc=en&product=306888
Posted on Sep 14, 2010
  • 193 Answers
SOURCE: Have an HP PSC 1510 printer. I put in a new
Problem After you install a print cartridge, one of the following messages appears on the color graphics display:
  • Incorrect Print Cartridge
  • Incompatible Print Cartridge
  • Problem with the Print Cartridge
  • Remove and Check [color / black or photo] Cartridge
  • [Tri-color / Black or Photo] Print Cartridge Inserted Now is Not Intended for Use in This Printer
NOTE: In the procedures below, the "problem" cartridge is the one identified by the message on the color graphics display. If the message does not specify a cartridge, perform the procedures on both cartridges. Step 1: Remove, inspect, and reseat the problem cartridge The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  3. Press down lightly on the end of the problem cartridge to release it. Figure 1: Removing the tri-color cartridge
  4. Slide the cartridge out and inspect it:
    CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 2: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear nozzle protective tape has been removed.
      CAUTION: Do not attempt to remove the copper electrical strip! Figure 3: Removing the clear nozzle protective tape
    • Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
  5. If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
Step 2: Clean the problem cartridge contacts
  1. Gather the following items to clean the cartridge and carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or a paper towel to rest the cartridge on during cleaning.
  2. Open the product cover and wait until the carriage is idle and silent.
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
    NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
  4. Unplug the product from the electrical outlet.
  5. Dip a swab in the clean water and squeeze it to remove most of the moisture. The swab should be only slightly damp.
  6. Clean the cartridge contacts.
    CAUTION: Do not touch the ink nozzles.
  7. Clean the contacts in the carriage, inside the product.
  8. Either let the cartridge sit for 10 minutes to allow the cleaned area to dry, or use a new swab to dry it.
  9. Reinstall the cartridge.
  10. Reconnect the product to the electrical outlet.
  11. Close the product cover.
Step 3: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above.
Call HP if the cartridge is covered under warranty to replace the cartridge
or its time for a new printer
Posted on May 06, 2011
  • 167 Answers
SOURCE: Ink installation problem!
install the printer software again
Posted on May 27, 2012
My hp printer is making a loud knocking noise and won't load paper. can it be fixed?
I would guess you have either the wrong cartridges or they are not seated properly causeing the jam. Try to remove each cartridge and reseat it carefully in the print head. while doing this be sure to check the number to match it with the printer. if this does not solve your problem, depending on the age of the printer, i would replace it. If it is warranty then get it repaired.
Sep 18, 2014 | Office Equipment & Supplies
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
Error message that paper jam in paper cradle
Try this:
  • open the lid of the printer (from where you can see the ink cartridges);
  • remove the ink cartridges;
  • use warm water and cotton swabs to clean both the ink cartridges and the print head (where the cartridges sit on) off of any ink residue;
  • place the ink cartridges back into the printer and test if this works by printing something.
If you're still having issues, there may be a mechanical problem; in which case you need to get it repaired by someone.
Oct 18, 2012 | HP Photosmart 8250 InkJet Printer
Hp printer photosmart c 4795
I don't have a photosmart, but I do have an HP OfficeJet J4680 that clicks sometimes. Check to make sure the ink cartridges are installed correctly. That's what is sliding back and forth when you turn it on.
Dec 17, 2011 | HP Office Equipment & Supplies
Epson R265 - prints blank (new inks & paper loaded)
Check the cartridges installations and make sure they're well installed.
Make sure the plastic tab around the new cartridges is completely removed.
Disconnect the printer completely and re-connect after a while.
Turn it off and on.
Problem solved?
Uninstall and install the printer again.
Hope this helps.Thanks!
Nov 10, 2011 | Office Equipment & Supplies
I replaced the black cartridge & when it said to run the alignment the paper comes out and looks like it's OK but the message comes up that slignment failed. Then if I ignore it and try to make a...
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Aug 27, 2011 | HP Photosmart C5580 All-In-One InkJet...
Printed photos have white vertical lines running throughout
Those are lines where the printer heads are not printing. Since in this printer the head is part of the cartridge you must clean the contact thoroughly, verify the data cable and replace the cartridges with original new ones.
If this doesn't fixes it then the defect is in the controller of the printer - the memory buffer that stores the image when it's received from the pc and sends it one line at the time to the printing heads . This cannot be repaired - the printer is dead.
Apr 17, 2011 | HP Photosmart C4580 All-in-One - InkJet...
I replaced a #57 cartridge in my Hp 7760, this AM.Since, it will not run a test/allignment page, nor run anything on paper. Iput the old #57 cartridge back in, rechecked all the cables, still win't print...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 19, 2011 | HP PhotoSmart 7760 InkJet Printer
6180 will not print black text
Are you using genuine or knock off inks?
Take out the blabk cartridge and knock in onto your hand while using a paper towel to absorb ink.
If ink comes out you have a communuication problen with the printer ink carriage or a defective cartridge.
Jul 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Vivera printer won't print
Take the cartridge out and clean the head with dry cloth and reinstall than then try.
also go to menu on the printer and out it back to factory settings.
Kevin
Feb 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6380 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
