Question about Bennett Marine Bennett DVD Back to the Basics of Boating What To Do When Things Go Wrong How To Prevent Them
I have a trail blazer 2005 and I just got it it runs good and has 71,600 miles on it now its making aloud rubbing noise or grinding sounds and my cluster is out for the speedometer
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 227 Answers
Sounds to me your speed om. cable is broke works of the tranny replace it see if the sound don't stop
Posted on Dec 19, 2013
I have 2003 Maradauer 800cc. When it is running for a while I hear rubbing sound coming from engine specially changing gear My guess is, water pump or is it my cam; chain??
Hi, Siamak I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have nice a day. Please help identify noise
Grinding Noise coming from engine
Rubbing Sound coming from the bike Kawa 2012 Ninja 250R 9 500 miles Fixxit
MediaFire
Jul 20, 2015 | Motorcycles
Front tires sound like they are rubbing on something
Your front brakes are shot. Its wear incater making the the noise.
Mar 28, 2014 | 2005 Volkswagen Jetta
2005 Suburban Front End Noise
check for hangings anything hanging may rub on other items and make a noise... you may have bent a rod for the drive section or cracked the case...look for fluid leaking
Mar 05, 2013 | 2005 Chevrolet Suburban
2005 dodge grand caravan 3.3 77000 miles starts and runs fine after initial mid grinding sound goes away approx 1 min and30 seconds warmup belts test good a little shine on major belt o
Sounds like something with bad bearings. Check in the area of air conditioner compressor or power steering and yes water pump.even the belt tightener will do that.
Sep 21, 2017 | 2005 Dodge Grand Caravan
2005 Ford Explorer is making a grinding noise
I had some issues with my 2005 explorer left rear. It was making a creepy old door sound at low speeds and then a high pitched whisel at high speeds. That turned out to be a broken wheel bearing and had it replaced. Note each wheel has two wheel bearings. After that a new noise developed that sounded like metal scraping/ grinding metal. It end up being the brake dust cover got bent when they replaced the bearing and it was rubbing something, the fix for that was bending it so it didn't rub. I hope this helps.
Sep 03, 2012 | 2005 Ford Explorer
Grinding/rubbing noise while driving
Could be the shield rubbing on the tire or could be a loose brake caliper. Get the brake assembly checked.
Mar 16, 2010 | 2005 Nissan Altima
Whinning noise from front of vehicle
check your idler, and tensioner pully's, i've seen a few trailblazers that whine and it turns out to be an idler pully, also check the power steering fluid and make sure its full in accordance with your owners manual
Jul 30, 2009 | 2005 Chevrolet TrailBlazer
Where is thermostac located on my 2005 (inline 6) trail blazer
You did'nt mention what engine you have. The illustration below is for a 4.2L, the most common for the trailblazer.
The arrow indicates front of vehicle.
Good luck, let me know.
Regards,
Jun 17, 2009 | 2005 Chevrolet TrailBlazer
Grinding noise while driving.
Possible causes:
a) a brake disc shield is too close to the disc, and it's coming into contact in the circumstances you outline
b) pebbles stuck between the disc shield and the disk
c) dried out wheel bearings
d) worn Universal Joints in the drive shafts
e) worn A/C pump
f) worn alternator
g) worn water pump
Is the noise still present above 15 miles an hour and past 1500 rpm when the clutch is disengaged (i.e. gearbox in neutral?). The answer to this question may help you to pinpoint the source. I know it's stating the obvious but the fact that you're hearing a grinding sound means it's caused by something that is moving relative to something else. Again this should help narrow down the cause.
Jun 01, 2009 | 2000 Chevrolet Blazer
Bennett Marine Bennett DVD Back to the Basics of Boating What To Do When Things Go Wrong How To Prevent Them Logo
63 people viewed this question
Top Bennett Marine Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Bennett Marine Boating Expert? Answer questions, earn points and help others
