Question about HP Mini 1000 Netbook
Not power and 3 and 5 volt - HP Mini 1000 Netbook
  • 62 Answers
You must connect exact volts.
Please stop connecting other volts capacity adapters
Posted on Jan 16, 2013
I have a mecc alte Mr 1 generator I'm producing 240 volts but I can't find a neutral so I can use 120 volts.where does the neutral come from
as 240 volts is single phase , it will not be possible to reduce the power by cutting across a neutral wire ( 240 volt power out and 240 volt neutral return That is ac power ) to do what you want to do you will need a 3 phase generator so that you can jump across a phase to get lower power
May 04, 2016 | Electrical Supplies
What is the Power supply for the Sony SRS-A21 speakers
count how many batteries it takes,multiply iot by 1.5 and then take that number and that is the voltage of the power supply that you need,1 battery is 1.5 volts 2 batteries is 3 volts 3 batteries is 4.5 volts 4 batteries is 6 volts
Jul 18, 2015 | Sony Audio Players & Recorders
Fault finding
Power is going to the motherboard, and you know this by assuming?
An assumption would be you see the Power Supply fan spin, LED lights light up, and maybe computer case fans spin.
Not an assumption, and you would have tested the 3 main voltage power rails, coming out of the Power Supply.
The Power Supply in your computer is an SMPS.
Switched-Mode Power Supply. (Also is known as the short abbreviation - PSU. Power Supply Unit)
http://en.wikipedia.org/wiki/Switched-mode_power_supply
The Power Supply in your computer is a Converter.
It converts HIGH AC voltage into 3 LOW DC voltages.
[Depending on country,
USA = 120 Volts AC. UK = 240 Volts AC. Japan is 100 Volts AC, but may depend on area. Australia = 240 Volts AC. India = 240 Volts AC. HOWEVER, do not write the above in stone. I may have made an error ]
The 3 low main DC Voltages coming out of the Power Supply is;
A) 3.3 Volts DC
B) 5 Volts DC
C) 12 Volts DC
Orange wires carry 3.3 Volts DC
Red wires carry 5 Volts DC
Yellow wires carry 12 Volts DC
ALL Black wires are Ground wires. They can also be called Negative wires.
This is a DC circuit now. There is a Positive, and a Negative.
Orange, Red, and Yellow wires are power wires, and also Positive wires.
The first part of your diagnosis will be to test those 3 main voltage power rails.
[Digressing;
Using an example;
There are many Red wires coming out of the Power Supply.
These are 5 Volt wires. They are Connected TO, the 5 Volt power rail in the Power Supply.
ALL 5 Volt wires end in one place, in the Power Supply.
The 5 Volt power rail.
When you test just ONE red wire, you are testing the entire 5 Volt power rail coming from the Power Supply.
This also goes for the Orange wires, and Yellow wires ]
With the Red 5 Volt wires, and Yellow 12 Volt wires, you could just use a 4-pin Peripheral power cable to check them,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Multimeter set to DC Voltage, the red (Positive) probe lead of the multimeter; touches the female metal terminal connector, for the Red wire.
http://www.mcmelectronics.com/product/28-9420&utm_medium=Affiliate&ref=cj&utm_campaign=CommissionJunction&utm_source=CommissionJunction?t=2&utm_expid=8634549-14
The black (Negative) probe lead of the multimeter, touches a female metal terminal connector, that goes to a Black wire.
You should be reading 5 Volts DC.
Same thing for the Yellow 12 Volt wire.
With an Orange 3.3 Volt wire, this changes.
A straightened out paperclip is inserted, down into the BACK of the ATX main power cable's connector; AND into a socket hole with an Orange wire in it.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The straightened out paperclip, slides down into the socket hole, with the Orange wire in it.
Slides down into the socket hole, RIGHT NEXT TO the orange insulation of the wire, and MUST go down far enough; to Touch that female metal terminal connector.
EVERY wire going down into the ATX main power cable's connector, ends in a female metal terminal connector.
Same thing is down with a socket hole that has a Black wire in it.
ALL Black wires are Ground wires. (Negative)
You can choose ANY socket hole that has a Black wire in it.
Now touch the two probe leads of the multimeter, to their respective straightened out paperclips.
Red (Positive) probe lead of multimeter, to straightened out paperclip in Orange wire socket hole.
Black (Negative) probe lead of multimeter, to straightened out paperclip in Back wire socket hole.
You should be reading 3.3 Volts DC.
(Or if your multimeter kit has special probe lead, that would take the place of a straightened out paperclip, of course use it instead)
Know this;
A) If ALL of the LED's ('lights') were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical CPU (Processor) can use 51 to 130 Watts of power.
Just depends on what Processor (CPU) it is.
This is why a Power Supply with a weak voltage power rail, will not have enough power to turn the Processor ON, but will have enough power to light those simpy LED's, and spin fans.
[LED - Light Emitting Diode ]
Regards,
joecoolvette
May 11, 2013 | Dell Computers & Internet
Smps on but display not showing
A) Check the monitor cable on a KNOWN to be working computer,
Or.
Use the monitor cable from the working computer on yours.
Monitor cable does not remove?
Use the monitor, AND monitor cable; on a KNOWN to be working computer.
B) SMPS may have a weak voltage power rail
[There are 3;
A) 3.3 Volts
B) 5 Volts
C) 12 Volts
ALL are DC Voltage.
In comparison two D cell flashlight batteries produce 3 Volts DC ]
1) If ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor (CPU) can use 51 to 125 Watts of power.
Just depends on what Processor it is.
This is why you may see LED's light, and maybe fans spin, but NOT enough power to turn the Processor on.
Use a multimeter set to DC Voltage, and check the 3 power rails.
ALL Orange wires you see are 3.3 Volts
ALL Red wires are 5 Volts
ALL Yellow wires are 12 Volts
OR,
Use a KNOWN to be good, Compatible power supply; for a temporary test unit.
Also, FOLLOW Anti-Static Procedures, with your unplugged from power computer.
DO NOT reach inside your computer if you are not.
Do not know what Anti-Static Procedures are?
Post back in a Comment.
PLUS, remove the Ram Memory modules ('Stick'), and reinstall them. One of them may be bumped loose.
NO. You cannot see it by eye alone. Remove, and reinstall.
This way you are ASSURED they/it, are installed tightly, and correctly.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 13, 2013 | ASUS P4P800 Deluxe Motherboard
Msi mobo RS480m2 powers up on 20 pin connector occasionally,but wont power up on 24 pin connector at all. why?
What are the 'extra' 4 wires, Cyprian?
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
They are 2 Yellow, 1 Red, and 1 Black.
Red = 5 Volt wire
Yellow = 12 Volt wire
Black = Ground wire
You have a bad Power Supply, with a weak voltage power rail.
There are 3;
A) 3.3 Volt power rail, (Orange wires are 3.3 Volt)
B) 5 Volt power rail
C) 12 Volt power rail
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
http://www.playtool.com/pages/psurailhistory/rails.html
3) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
MicroStar Intenational RS480M2 can use processors that take a LOT of Wattage,
http://www.msi.com/product/mb/RS480M2.html#/?div=Detail
With a weak voltage power rail you do not have enough power, to turn the Processor on, and keep it on.
Picture that.
Do you wish to test the Power Supply?
Or do you have a KNOWN to be good, Compatible power supply; that you can borrow for a test unit?
Regards,
joecoolvette
Nov 18, 2012 | MSI Computers & Internet
Dell dimension 5510 it will not turn on, no
1/10th a volt? Nope.
Bypass the Power On switch. See if you have a bad switch first.
Then test the power supply. If the power supply comes on by bypassing the Power On switch, I'll bet you have a weak 12 volt voltage power rail.
1) Yellow wires are 12 Volts
2) Red wires are 5 Volts
3) Orange wires are 3.3 Volts
4) ANY Black wire is a Ground wire
They do sell power supply voltage testers, should you not wish to use a multimeter set at DC volts.
(0 - 50 Volt scale)
I prefer a multimeter.
A) ALL the light use less than 1 Watt
C) A typical Processor uses 55 to 125 WATTS.
You have to turn the power supply on, by jumping the Soft Power On wire to any ground wire.
This is also the way to bypass the Power On switch, to see if the switch is bad.
Do you wish to proceed?
Jan 15, 2010 | Dell Dimension E521 PC Desktop
LCD tv issue
at error code is 12 and it is your 12-volt supply. Measure from the inverter to the power supply for 24 volts pins 1,2 and 3. If you don't have the 24 volts disconnect the inverters from the power supply and see if the volts come up. If the 24 volts come up replace the inverters. If the 24 volts are still not there replace the power supply. The volts have to be steady and not going up and down if they are replace the power supply.
But if the 24 volts are there with the inverters connected 1M03 pin 3 for 3.2 volts. If the 3.2 volts are not there replace the small signal board. The only way to get a manual is to find it on line or call the manufacture.
Aug 26, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
HP Mini 1000 Netbook Logo
15 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
