Question about Canon Mp25diii
Have Canon Calculator Model MP25DIII need part that holds paper and feeds it thru slot with edge to tear paper off
  • 106 Answers
SOURCE: Trouble Feeding Tape into Calculator
use a thin plastic card and put it on the load,maybe you have a paper on printer ,press feed and you vill clear all paper path
Posted on Feb 01, 2008
  • 168 Answers
SOURCE: Staples SPL-P100 calculator feed
There could be something stuck inside the unit. Try taking a business card and pushing it into the silver slot at the same time pushing the advance button.
Worst case senerio, bring it back to Staples and ask someone there, IM sure that someone there can get the paper to feed in seconds if there is nothing else wrong with it.
Sorry I couldnt be more help.
Good luck.
Mac
Posted on Feb 10, 2008
julzgaye
  • 3 Answers
SOURCE: loading paper
The entry point is on the back bottom of the machine. Cut your paper into a shallow triangle w/a slight point in the middle. Guide it through the slot on the back, and then lift that point up so that it goes into an almost invisible opening with small silver metal tabs on either side. The paper will want to feed underneath the entire black plastic mechanism, but don't let it. As the instructions indicate, the paper does not actually feed "under the black plastic plate", but through it. After you manage to insert the point of your paper through the correct slot, make sure the entire edge of the paper actually enters so it is grabbed when you push "Feed."
Posted on Feb 07, 2009
  • 45 Answers
SOURCE: how to feed paper into a canon palm size printing
There should be a small slot in the rear, gently feed the end into it while pressing the paper feed/advance button.
Posted on Sep 08, 2009
SOURCE: We can't figure out how to feed the new paper into
The calculator wouldn't take the paper but when he cut the corners off the paper to make a blunt "V", it grabbed the paper right away and pulled it through.
Posted on Nov 07, 2009
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    HOw do I load paper?
    I can help you with your Canon Calculator problem.
    Load the paper roll but pushing it into the lowest slot, then holding down the paper feed button (up arrow button) until it feeds it through long enough to tear off.
    I hope that helps.
    Sep 26, 2010 | Canon P23-DH Calculator
    Need to know how to insert printing tape into Canon P23-DH color printing calculator?
    Install paper roll with end coming up from rear. Insert end of paper into slot at back of calculator until it stops. Then press feed button until paper advance thru slop at top.
    Jul 17, 2010 | Canon P23-DH Calculator
    Ativa AT-P500 calculator; how do I put feed paper into it? Is there a manual for this?
    I have the same problem (no manual) but solved it: the port of entry for the paper feed in located on the back, near the bottom. The top piece (where you tear the paper off) moves slightly to the back and can be removed. Feed the paper into the machine; pull out a few inches asnd cut the edges of the paper, about two inches back, into a "V" and feed this point into the slot just below the "ridge" and press "feed". Problem solved!
    May 16, 2010 | Office Equipment & Supplies
    How do I install adding machine paper roll
    Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
    If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
    If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
    Nov 23, 2009 | Canon P1-DHV Calculator
    How do you load the paper?
    Aug 31, 2009 | Canon P23-DH Calculator
    How to load the paper into casio hr 100T . My son just came home with this old model. It has paper provided but no instructions. How do we get the paper to feed and in what directions does it need to be...
    I have a casio HR-100 TM. After spending over an hour, and scouring the casio website which had an obscure spot that covered a totally different calculator!.... I found a slot in the back of the machine that when I folded the paper into an arrow, FINALLY went in! You may have to try a few times, but it will go in just keep holding down the feed button as you push and jiggle the paper.
    Jun 20, 2009 | Canon P1-DHV Calculator
    LOADING NEW PAPER
    HOW DO I LOAD PAPER INTO THIS
    Aug 10, 2008 | Canon P23-DHIII Calculator
    Register tape
    Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
    First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
    Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle. Looks like >
    Then, place the paper into the slot where the paper feeds into in the back. (Paper will get fed under the printer assembly) and then hit the PAPER FEED/ADVANCE button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
    Hope this helps.
    Have a good day.
    M =)
    Feb 13, 2008 | Sharp EL-2192Rll Calculator
    PAPER FEED
    Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
    Hope this helps.
    Have a good day.
    M =)
    Jan 16, 2008 | Canon P1-DHV Calculator
    Canon Mp25diii Logo
    old marine
    old marine
