Question about Air Tools & Compressors
Electric motor turns on barely turns the trips breaker
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
SOURCE: Tripping the electrical Breaker
I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
The heater element can be cleaned when cold with a very mild detergent and room temp water.
If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet on a 20 amp breaker.
Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
The heater element will cycle on and off during normal use.
Good smoking and enjoy.
Posted on Nov 24, 2008
  • 389 Answers
SOURCE: keeps tripping the main breaker on the electrics
Sorry if this is stating the obvious, but this is a sign of an electrical fault. Specifically, what trips the main breaker is leakage to earth (ground). You need a qualified electrician.
Posted on Feb 18, 2009
  • 67 Answers
SOURCE: Electric Air compressor just hums then trips breaker.
usally there is a releaf valve that takes the pressure off the compressor while it is resting. If that pressure is not off when the drive piston starts the motor will overload and blow the the breaker or reset. Check for a releaf valve for when the unit has reached full pressure
Posted on Jun 16, 2009
  • 5603 Answers
SOURCE: motor trips breaker
The speed is going below where the starting winding cuts back in. That will wreck the motor in short time! The current will shoot up a factor of at least three when the start winding activates.
Investigate why the load is excessive on the motor. Is the motor undersized or is the compressor have a problem? Low oil and bearings seizing?
Posted on Sep 26, 2009
Why does the breaker keep tripping on this 2.0hp exhaust fan motor
Christopher, motors starter/capacitor could be faulty, wire circuit/breaker could be insufficient. motor could be faulty or wired incorrectly. Have motor checked out and ensure you are wiring correctly.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LEESON Electric Motor Trouble Shooting Chart
Motor trips breaker Why
http://www.garagejournal.com/forum/showthread.php?t=256105
Jun 03, 2016 | Heating & Cooling
Every time I turn my dryer on it trips the breaker box and I don't have any electricity.
Assuming this is and electric dryer, there must be a short or a bare wire touching bare metal somewhere in the dryer. I would suggest looking at the element and seeing if the element has melted into and is touching the side of the housing.
Apr 14, 2011 | Dryers
How dou you connect the electical wires I connected them and it throws the breaker
Look at rating plate on motor.
Look for volts, watts, amps.
Figure with Volts x Amps = Watts.
Amps = Watts divided by Volts
1 hp horsepower is 756 Watts.
Lets say you have 120Volt 2hp motor
So 2 horsepower motor draws 1500 Watts
Amps = 1500 Watts divided by 120Volts = 12.5 amps = so you need 120Volt 15 amp breaker with at least 14gauge wire (as long as motor is located within 50 feet of breaker.)
If motor is farther away, then you need 20 amp breaker with 12gauge wire.
Look at circuit breaker rating.
If motor is 240 and breaker is 120, then it will trip breaker.
If motor is 120 and breaker is 240, then it will trip breaker.
If breaker is for 15 amps and motor draws 20 amps then it will trip breaker.
Generally speaking, if motor and breaker are 120V, then black wire goes to black wire; white wire goes to white wire and green wire connects to bare copper wire.
If motor and breaker are 240V, then wire colors can be different. Black-red or Black-white from breaker connect to Black-red or Black-white at motor.
Add a comment. Say the motor rating and color of motor wires. Say the breaker size and color of wires coming from breaker and I will help you wire the device.
Nov 27, 2010 | Northern Industrial Tools Electric Meat...
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
The circuit breaker on the unit pops almost every time I use the unit, what might be causing this?
Hi, when the breaker trips every time you turn it on, the unit has a dead short. It may have a frayed wire where it goes into the units motor, or the motor it self may be shorted out.A bare hot wire that touches metal will pop the breaker right away. I would look the cord over very well to see if anything may be bare. If not, the problem is further into the motor section of the unit, and more then likely the motor has failed. This is why the breaker is there for this reason. In case it overloads or you have a short, it trips to keep the unit from burning. Please keep me posted.
Sincerely,
Shastalaker7
Feb 05, 2010 | Vacuums
Intermatic t10004 control panel trips the circuit breaker
That circuit breaker is letting you know that you've got a problem in the electrical wiring.... What's next is to turn the power off to BOTH legs of the breaker.
Begin by physically inspecting all the connections in the timer box, and at the breaker and all the way to the pump motor. Make sure all connections are dry, and there's no water in any of the conduits...this will cause a short circuit and trip the breaker. If there's any bare power leg wires touching a grounding point , this can cause the breaker to trip. Lastly check the motor on the pump; on the motor end, there should be a cap you can remove and use a crescent wrench to make sure the motor shaft is moving freely. It could be jammed with debris....this happens around my pool often because I'm surrounded by trees with needles. If the motor cannot turn freely, this will cause the breaker to blow... I'm pretty sure that your timer isn't the issue... Please let me know what you find out.
Nov 19, 2009 | Intermatic T10004R - Pool-Spa Mechanical...
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
My electric range is tripping the circuit breaker
unplug the unit and see if maybe you have a problem in the breaker/supply line from the house panel, otherwise does it work fine?,there also may be a bare or shorted wire in the unit itself
Aug 09, 2009 | Kitchen Ranges
How to manually reset an AO Smith 2 hp motor?
If you did not press a reset ( and even if you did) the motor is damaged and that is causing the circuit breaker to trip. You need to have the motor inspected to see if the damage is repairable or if you need a new motor. A local electric motor repair shop should be able to take care of that for you. The thermal overload has reset itself if after cooling down the motor is trying to start but trips the breaker.
To be certain it is the motor, disconnect the line leads and be sure they are insulated from ground and one another. Turn the breaker back on. It should stay closed which confirms it is the motor tripping it when connected.
If for some reason the breaker still trips, there is a problem with the electrical circuit feeding the pump.
Jul 26, 2009 | AO Smith A O Smith Motors A O Smith 2hp...
Warm air furnace
If you are not familiar with electrical wiring, I would suggest an electrician. NEVER TRUST COLORS! Most of the time, white goes with white, black with black, red with red, and bare to bare. But depending upon whether this is a 110 or 220 they could be mixed up depending upon how the feed wire is wired at the box. Hope this helps! c
Oct 03, 2008 | Electric Circuit Breaker Kit for Furnace
Air Tools & Compressors Logo
43 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
