Question about Home
Is it safe to use an empty softener bottle to store liquid?
    Guru:
  • 269 Answers
Technically, you can reuse a softener bottle for other things but I would make sure that you clean it very thoroughly, especially if you plan or storing something edible. Most softeners would be considered toxic so you need to make sure there is no trace of it left in the bottle when you refill it with something else.
Posted on Jan 16, 2013
  • Geoffrey White
    Geoffrey White Sep 05, 2013
    I'd add that if it is regularly used for drinking from after that, there is the danger that someone will drink from a bottle still having softener in it. Scrape off or obscure the label.
How do I get rid of small pieces of mildew that appears after washing. Cleaned everything on washer I can see. Ran the cleaning cycle 3x, sanitizing cycle 1x
Mix vinegar and bleach put in spray bottle,wear rubber gloves,spray on the mildew,scrub it,then run a rinse cycle.
Jul 15, 2015 | Kenmore Washing Machines
Samsung washer softener
2 possible reasons for your issue, you might be filling the softener compartment too full, or possible pushing the tray in too forcefully causing the siphon action to occur which empties the compartment. Pleazer Appliance...
Apr 13, 2014 | Washing Machines
Htwp1200doww where does fabric softner go
You have to do it manually. Ugh. See below from manual:
Liquid Fabric Softener (Manually add during rinse cycle)
1. Turn OPTIONS knob to FABRIC SOFTENER
2. Measure liquid fabric softener carefully, following instructions on the bottle, and add during the rinse cycle.
OPTIONS (on some models)
Set this option when planning to manually add fabric softener during the rinse cycle or when you use extra detergent or bleach to clean hazily soiled items. It provides an enhanced rinse.
Oct 04, 2012 | Hotpoint Washing Machines
G155
You have to do it manually. See below from manual:
Sep 09, 2012 | Hotpoint Washing Machines
Liquid softener only empties when it feels like it.after a load i look and it's still in its section??
Remove the detergent / softener drawer and wash off with hot water, the hole that the softener flows out of is pluged up.
Oct 27, 2009 | Maytag EPIC MFW9700S Front Load Washer
The fabric softner reivore wont take in/ empty the fabric softner
I had this problem also. I pulled the drawer out, then removed the softener assembly. (the blue piece) In the front there is a hole that lets the softener liquid drain into the funnel to go into the machine. It was clogged with a little bit of dried up softener liquid. Cleared that and it worked fine. We've had the washer for 3 years and have had to do this several times. Seems to be a problem.
Oct 08, 2009 | GE WBVH6240F Front Load Washer
Fabric softener dispenser not working
If the model number you have this listed under is correct, you should have the softener dispenser on the center post of the agitator. If this is the case, you need to remove it by popping it off the center post and take it apart. Soak it in some hot water to dissolve the softener residue and reassemble. Most dispenser related problems are attributed to softener that hardens and clogs up the dispenser. Liquid softener is essentially a wax and will do this over time. You will need to clean it from time to time.
Apr 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bleach & Softner not emptying
What "form" are you using? liquid, gel, powder? try using a different type and lean towards the more liquid forms if your washer can handle them, ie move from powder to gel or liquid, and from gel to liquid. Hope this helps.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Home Logo
345 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
