Question about Engines & Components for Toyota 4Runner
What does a toyota code p000a and p050b mean
The ABS and BRAKE light a on and the car drives fine.
    New Friend:
  • Toyota Expert
  • 83 Answers
P050B: Idle ignition timing problem at cold
Posted on Dec 09, 2013
My 2007 abs and bake light is on what could be the problem
check the level of brake fluid in the reservoir of the master cylinder
run the fault codes to determine the problem sensor
Nov 05, 2015 | Toyota Cars & Trucks
How i can fix abs land cruiser 2008
-Why you know ABS is not working...?
-ABS is working ONLY when you Stop suddenly. And your foot
MUST hole Still.
-Here how you test your ABS. It's still working or no:
*Make sure NOT On Street! Drive the car about 20 mile per hour and then immediately brake (Full Brake. Do not release your foot. If you feel like the brake lock and unlock the wheel but very fast. This mean Your abs is working fine.)
Even the ABS is not working the regular brake still work.
Don't worry about.
Good Luck.
Mai Lor
Apr 26, 2015 | 2008 Toyota Land Cruiser
Vacuum brake booster toyota sequoia 1984. Brake Dealer completed diagnostic test showing codes C1223,1247,and 1310. Conclusion the booster needs replacement. Must I? (about $1,000). Safety issue???
Toyota Sequoia's had a lot of problems abs wise> #1 clear codes with a factory software scanner. then drive it to see what returns. I can not see a brake booster setting 3 codes that are ABS/VSC problems #2 how does the brake pedal feel If it is high and hard pedal then the booster is bad if the engine speeds rise as pedal is depress and you hear escaping air the booster is bad. #3 ABS/VSC are supplemental systems to the normal braking soit will take longer to stop and a possible skid could occur. but you will stop leave more traveling space you should be fine.
May 07, 2014 | Toyota Cars & Trucks
Reset abs warning light repair
Could be your brake fluid is low or your abs sensor is bad,here's a link to your sensor.
Nov 25, 2013 | 2009 Toyota Corolla
91 Buick park avenue abs light. This happened after my friend was driving down the freeway and his tire blew. Now it just blew the rubber off and he was able to drive t off the freeway on the belts. And...
ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti lock brake system light comes up when there is issue with car brake systems. It can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly. Your vehicles brake system needs inspection.
To troubleshoot these issues, I suggest you to refer the help links provided below. There are direct links with accurate solution, for these specific issues.
Click the link below and follow the procedure: ------
All types of ABS LIGHT / brake problems and repairs
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
VCS and ABS lights go on and off intermittently on Lexus?
http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction Control Lights stays ON dash of car?
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Battery Light and ABS Light on Dash
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
How Anti-Lock Brakes Work?
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Anti-lock brake light stays on all the time?
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
2008 Toyota Highlander: ABS warning light Blinking and OBD Error codes Coming?
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
2003 Lexus ES: VSC, TRAC OFF, ABS lights ON?
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
2008 Toyota Highlander Hybrid: Warning Lights Abs, Vsc & Brake Are On?
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
ABS & Brake warning lights remains steady on dash?
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse connected?
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
Where is ABS/TCS module located on 2005 Cadillac Deville
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
ABS motor keeps running?
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON?
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century?
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade?
http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
Toyota Camry: Premature ABS Actuation?
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
Esp and abs light on in 2009 ford transit how do i eliminate them
Anti lock brake system light comes up when there is issue with car brake systems.It can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly.Your vehicles brake system needs inspection.
To troubleshoot these issue,i suggest you to refer the help links provided below.There are direct links with accurate solution,for these specif issue.
Click the link below and follow the procedure:------
VCS and ABS lights go on and off intermittently on Lexus? http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction Control Lights stays ON dash of car? http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
------------- ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
Battery Light and ABS Light on Dash http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while Driving? http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
----------- How Anti-Lock Brakes Work?
Brake System Troubleshooting? http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
ABS & Brake warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse connected? http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
ABS motor keeps running? http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON? http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century? http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade? http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
-------------- Toyota Camry: Premature ABS Actuation? http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
Thanks.
Nov 24, 2012 | Ford Transit Connect Cars & Trucks
ABS warning light What does this mean?
Means your anti locking brake system is disable, when the ABS light is on means the ASB computer pick up a bad signal from one of your ABS sensor's, any auto parts place like autozone can do a free code reading, once you get the code get back with us here at FixYa so we can help you diag. your trouble code, also your brake will work fine it be like a car with out ABS, get it check out.
Jun 03, 2010 | 2003 Honda CR-V
1996 Ford Windstar 3.8L, Brake light is on-brakes work fine
Abs light on means the ABS sytem has a fault.
You can determine what is wrong by counting the flashes (they say) and then put the data in on the web.
IE abs, windstar, failure, 3 flashes.
The brake light on is most likely picking up on uneven brake pressure, or a failing master cylinder/
You may not feel any difference yet, give it a little time, feel for a pedal fade at a light.
Jan 23, 2010 | 1996 Ford Windstar
2005 toyota prius abs brake not working warning light and abs lights all stay on toyota cant fine problem they say the brakes are fine they want to put in a main chip which well cost $2500 i beg to differ...
Hmm, I'm not sure what a main chip is but, there is a few reasons for this problem.
  1. ABS Sensors - there could be something wrong with a sensor and/or the wiring to them
  2. The wheel bearing speed sensor in a wheel is bad or intermittent which then tells the computer that wheel is traveling at a faster or slower rate of speed then the rest which in then the computer turns the abs light on.
Now when your warning lights go on, the computer sets a DTC code which is the key to helping solve this problem. If you can get the DTC (Data Trouble Code) from the dealership or from someone who can scan your can, I can better assist you in figuring out what's wrong. Hope this helps.
Oct 20, 2009 | 2004 Toyota Prius
Warning Light on the dash is illuminated all the time and it says, "BAS ESP"
This is the Brake Assistance/Electronic Stablilty malfunction light, it is the equivalent of an ABS (antilock brake) / electronic suspension control (traction control, rollover control, electronic suspension control) light. It basically means you have a problem in either your electronic ABS, traction control, or some other advanced electronic suspension control problem... Your car is fine to drive like it is, unless you detect some other driveability issue other than the dash light... (99.9% of the time it's something irrelevant and maybe stupid; that's what you get for driving electronic cars...) Your best bet to get rid of the light would be to get the car to an auto shop with a reader that can read ABS/EBS, brake and suspension codes to really find out why the light is on (usually a wheel speed sensor, or something like it...)
May 07, 2009 | 2005 Dodge Magnum
Engines & Components for Toyota 4Runner Logo
179 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
