Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 not used for 2 years will not come to life!
  • Dell Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 16, 2013
  • 62 Answers
SOURCE: cpu upgrade dell dimension 5100
Hi, according to the Dell website you have a LGA775 socket on your motherboard. Therefore, you can only buy processors that fit into this socket. Here is a list of some offered by Intel that will work: Celeron D 325 2.53 GHz Celeron D 330 2.66 GHz Celeron D 335 2.8 GHz Celeron D 340 2.93 GHz Pentium4 520 2.8 GHz Pentium4 530 3.0 GHz Pentium4 540 3.2GHz Pentium4 550 3.4 GHz Pentium4 560 3.6 GHz Pentium4 570 3.8 GHz The processors that won't work are the ones that are not compatible with this socket. Everytime you look up a cpu it will tell you which socket it is designed for. To buy a cpu you will need to decide: The brand you want. The speed of the cpu that you want. Extras i.e. Hyperthreading, etc. How much you are willing to pay for it. Then you can narrow your search as you stick within your limits. Let me know if you have more questions. Good Luck
Posted on Oct 01, 2007
pagebor
  • 2785 Answers
SOURCE: Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Posted on Sep 03, 2008
SOURCE: Dell Dimension 5100 Fan Replacement
rearward removal, there are a couple of latches you have to push so you can slide it backward (towards the processor end) and lift it up, one of the latch is next to Hard Disk compartment and the other one is on the other side. dont forget to clean the thermal paste on the processor and heatsink and reapply new thermal paste when you put everyhing back.
Posted on Dec 25, 2008
  • 565 Answers
SOURCE: Dell Dimension 5100 - CPU & Motherboard/System Temperature
u can also look rhe temperatures in bios under pc healt
Posted on Dec 26, 2008
graemevm
  • 519 Answers
SOURCE: How do I return our Dimension 5100 Dell Desktop back to it's original state? Lost the recovery CD.
Have you tried restoring your operating system to a previous restore point?
To do this click on start- all programs - accessories - system tools - system restore. Then choose a date from the calendar which corresponds to a time before you began to experience problems on your PC. Follow the on-screen instructions to restore your PC to its original state.
Note that a system restore will remove any programs which were installed AFTER the selected restore point date.
Hope this helps.
Regards,
Graemevm
Posted on Apr 19, 2009
How do I remove the motherboard from a Dell Dimension Model 5100
Anonymous,
You can click the link below to download the online manual for the Dimension 5100 system. The manual provides information for removing/replacing parts within your computer.
Dimension 5100 Online Service Manual
http://dell.to/1vEC70f
Thank You,
Dell-Jesse L
Dell Social Media and Communities
#iwork4dell
Oct 02, 2014 | Dell Dimension Computers & Internet
Power supply instalation manual for dimension 5100
power supply installation for dell dimension 5100 is not that much hard, what you need to do is to remove the old power supply and unplug the cable from the mother board
Oct 26, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
What is the maximum drive size I can install on my SATA controller?
Looks like at least 400Gb see below.
Product Details for 5100 400Gb Desktop SATA Hard Drive This SATA Hard Drive is used and has been tested for proper functionality.
Dell Dimension 5100 400Gb Desktop SATA Hard Drive.
Hope that helps.
Feb 25, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Need to purchase recovery disk for pc desktop DELL DIMENSION 4550
You can do it two ways:
1) call Dell and order a recovery CD--their contact info is on dell.com
or
2) use a regular Windows CD and install the system using the product number affixed to the case. Then go to Dell at support.dell.com to download the needed drivers.
Oct 08, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Just come back from a 2 week holiday and my dell dimension 5100 was off but i usually have it on 24/7. having returned from holiday , when i press the power button nothing happens but the yellow l.e.d...
This model has had a very high failure rate. The amber led on front is on to show an error. This can be 1 of 3 things. 1. The power supply has went bad. 2. The motherboard is bad. or 3. The front control panel is bad. Since Dell used proprietary parts on this model you would need to contact them for replacement. www.dell.com will have the contact info. Hope this helps.
Sep 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Slave drive into Dell Dimension 5100
Yes it does. It may not have an IDE cable if using SATA hard drive, but it does have a port on the motherboard to plug in the cable you take from your 4600.
Don't forget to rate your answers please!
Jun 07, 2008 | Dell Dimension 4600 PC Desktop
Dell dimension 5100 motherboard
I would try asking dell.go to www.dell.com lala linda
May 18, 2008 | Intel D845GVSR Motherboard
High Hard Drive Temperature
you can check zalman's homesite. http://www.zalman.co.kr/eng/main.asp
I can recommend them to you.
CS.
May 16, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power supply ?
I'd recommend purchasing a new power supply.
Your Dell Dimension 5100 comes stock with a 305W power supply. This is a bare-minimum wattage that will only handle what they ship on the system & not much more. You're better off upgrading the power supply with a compatible after-market model.
You can go to a PC parts store in your area and take your chances...but they're usually more expensive then Internet sources (they've got to pay for their brick-n-mortar store overhead).
Here's a link for a very inexpensive replacement 400W power supply for your Dell Dimension 5100:
http://www.affordablesurplus.com/dell-5100-5150-power-supply.asp
This particular site offers $8 Flat-rate shipping & a 1 year warranty. Your power supply is only $49.99 - you might be able to find it cheaper elsewhere, but that's the best I could find with a quick Google search.
If my answer helped you, please provide feedback :-)
May 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
16 people viewed this question
Alun Cox
