Car Audio & Video Logo
Posted on Jan 16, 2013
HOW DO YOU FIX A COIL IN A SUBWOOFER
WHEN HOOKED UP , WITH THE VOLUME ALL THE WAY UP . I ONLY HEAR A QUIET, bad BASS SOUND
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jan 16, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
1255
Points
21
If its truly a bad, burned up voice coil, its generally not worth replacing unless its a competition sub. you can get good sounding subs for under $100.
5 Related Answers
crispin melchor
  • 231 Answers
  • Posted on Dec 07, 2007
SOURCE: Subwoofer help
hard to tell whats causing this .Just curious make sure speaker wires going to subs are POLARIZED meaning positive from amp is with positive at woofer and NEGATIVE is with negative at woofer.When these are crossed and when volume is raised you will hear the bass cancell each other out..
linktriscuit
J. Fernandez
  • 89 Answers
  • Posted on Nov 13, 2008
SOURCE: fusion amp . the green
First your need to make sure that the amplifier is grounded properly. And verify that all other connections are as well. Unfortunatelly, i wouldn't be able to help you because i need to be in front of it to troubleshoot. Hope you fix it.
Anonymous
  • 68 Answers
  • Posted on Nov 19, 2008
SOURCE: Subwoofer: diamond tdx10d4
you could go back into the wiring systems and by past the button,.then put a toggle switch there so u can keep it on when u want or toggle it off to turn off the system
Anonymous
  • 10 Answers
  • Posted on Sep 03, 2009
SOURCE: bass sounds muggy it rattles alot when volume is
Have you had it checked out, if it rattles when bass hits hard, it could be busted, have you had it up extremely loud before? If so, that is probably what done it, otherwise, I would call whoever you bought it from, and ask them if they know anyone who has had similar problems to yours.
Anonymous
  • 10 Answers
  • Posted on Apr 14, 2010
SOURCE: I hooked up a 2-Ohm dual voice coil 800 watt max
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
2answers
I turn on my subwoofer and the volume is turned down and it makes a loud buzzing sound, and its not even hooked up to the amp, just pluged in. Thank you, Joel Arntsen
You might have blown the speaker. This happens when you play things too loudly and you ruin the speaker inside. You can test this by playing something with a decent amount of bass and turned up a bit. If you hear like a "rattle" in the sound or like something isn't right in the heavy bass notes, then you definitely blew the speaker out. This isn't a tragedy. They're fixable if you bring them to a place that repairs speakers. But I would definitely test it first by hooking it up and playing a loud song with a lot of bass. Hope that helps a little! Please rate my solution!
- Frankie
I get a red light on the back panel labeled power. No green light. I don't think the PV 600 is working but when I run the channel check through my Pioneer THX receiver I hear sound. Any thoughts?
The PV600 and PV400 have auto-on circuitry that turns the subwoofer on when a signal is presented, and turns off if no signal is detected for 15 minutes.
http://www.retrevo.com/support/Boston-Acoustics-PV600-Subwoofers-manual/id/522dj484/t/2/
Not knowing which Pioneer receiver you have I have dropped in the steps for No Sound from Subwoofer:
• Check that the subwoofer is connected properly, switched on and the volume turned up.
• If your subwoofer has a sleep function, make sure it is switched off.
• Make sure that the Subwoofer setting is YES or PLUS (see Speaker Setting on page xx).
• The crossover frequency may be set too low; try setting it higher to match the characteristics of your other speakers (see Speaker Setting on page xx)
• If there is very little low frequency information in the source material, change your speaker settings to Front: SMALL / Subwoofer: YES , or Front: LARGE / Subwoofer: PLUS (see Speaker Setting on page xx).
• Check that the LFE channel is not set to -80dB , or a very quiet setting (see Bass Peak Level
on page xx).
• Check the speaker level settings (see Channel Level on page xx).
Regarding the Large vs Small assignment of speakers, what they mean isn't so much the physical size but the ability to handle real bass. Large if Yes.
Subwoofer FPS 1000 4.1 sound bad
hello,
I had a problem closely with my FPS 1000 4.1 sound works four point surrond : my subwoofer sounds a metallic noise when the bass are loud.
Maybe it is the same problem ? :
It were vibrations that go through the subwoofer and cause the noise.
Check the four screw well (the four hole on the back of the subwoofer). Put your finger on them to clog them and hear if your problem is solved.
If yes, put scotch on them.
Secondly (i think you have disassemble your subwoofer), you can put silicon joincture on the box near the circuit, under the translucides cables. (the box where there are the plugs). >> if there are any hole between his box and the speaker, there will be some metallic noise (vibrations trough the box and the back plugs).
bye
5.1 surround sound
Here is how you fix it. Its really easy actually take a look at your Subwoofer 99% of the time you can control two controls for your bass somewhere around the Subwoofer. If you raise the volume of your Subwoofer you'll get more bass. Try it and let me know how this works out for you alright.
Bass sounds only
That is tricky one. Did you try adjusting the EQ on both the stereo and the amp? Is the Mute turned on because it will act like that? Is both rca jacks plugged in on stereo and amp?
Help
Hi Cassie, unless your receiver is a surround reciever, it won't have an actual subwoofer output. The good news is that you can use either a "line out" jack or a "tape out" jack instead, which most receivers do have. These jacks always have the signal, so there are no special settings to remember - simply operate your receiver as usual. Everything comes out of these jacks, not just the bass - but it won't matter since your subwoofer will only reproduce the bass frequencies. The bass information is generally identical in both left and right channels, so either the right or left jack should work fine, and it's okay to leave the other one unconnected. The only bad thing is the line and tape outputs are not affected by the receiver's bass and treble controls, so you'll have to control the bass volume at the subwoofer if it has a control. If you can't control the amount of bass you hear, turn up the volume and reduce the treble which will give the illusion of more bass. I'm assuming you have "powered" subwoofer (has its own built-in amplifier). Good luck!
Rattle Problem w/ subwoofer
When you put the new foam, maybe the cone went off center. Get a new kit, and re-do the job with more care. Check to make sure that the spider is okay, and that the speaker coil is not warped or anything like that.
There are speaker companies the professionaly rebuild speakers. They are better equiped and have the jiggs and facilities to properly rebuild the speaker from the coil up.
If you really want your speakers, you should consider giving the complete set out for rebuilding and testing.
Jerry G.
Z5300e Subwoofer Problem.
in my view, it is due to any of the following
1. its fuse burnout or wire breaked, check fuse and cordwire
2. its subwoofer coil is damaged to loud volume, replace it
3. its amplifier IC is damaged, replace IC
2helpful
2answers
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
