Question about Fujitsu LifeBook N3010 Notebook
Sound isnt working on fujitsu n3010
I recently bought this laptop and sound isnt working, ive tried updating the drivers, but it still isnt working. i checked to make sure everything isnt muted, and still no sound
  • buslog Apr 15, 2009
    Same problem with mine. I was able to get headphones to work a couple of weeks ago but now nothing.
Fujitsu N3010 lifebook internal mouse will quit working after a few minutes after boot up
Do a full anti-virus scan of your system, if okay! try a system restore bring computer back in time before this happened.
Apr 20, 2012 | Fujitsu Siemens LifeBook N3010 Notebook
I recently bought a Dell Inspiron N3010 in September. Within the first few weeks of purchase, the laptop blue screened me. I maintain my laptops very well, and avoid downloading junk programs, as well as...
driver or hardware problem if it is happening when using the web cam and mic then thats a good place to start update the divers for them and see if it takes care of the problem
Jan 28, 2011 | Dell Inspiron 13R (N3010), 14R (N4010),...
Sound isnt working but all my settings say they are working properly and I get a problem with playback
1. Go to control panel>Device Manager
2. Select your audio device, check the properties
3. Check if its disabled. if not then upgrade or reinstall the driver.
4. If not working then check master volume control, if its mute by mistake.
5. If still not working, put external speakers and check if sound is comming.
6. still sound is coming then need to check & change your laptop speaker.
7. If still no sound, then need to check your motherboard.
Aug 21, 2010 | Fujitsu LifeBook N3010 Notebook
Computer does not recognize the cd-rom drive
possible, you can also search if your registry files have Upper and lower filters, the path is HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
then restart PC
Jun 16, 2010 | Fujitsu LifeBook N3010 Notebook
Need to replace a keyboard on a Fujitsu Lifebook N3010. Dropped beer on it. Now some of the keys aren't working. Would like detailed inst's on how to crack this comp open.
I have stripped many laptops down and to remove keyboard is reasonably complex and replacements are also expensive. Dowload a manual off the net is the best and follow instructions to the letter. Ther isnt enough room here to describe the procedure.
Nov 20, 2009 | Fujitsu LifeBook N3010 Notebook
How I can down load audio driver for N3010?
Follow this link to the driver downloads page at Fujitsu. Choose Notebook PC > N series >N3010 and all of the drivers will be available to download.
http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADS
Oct 18, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
How I can down load audio driver for N3010 lifebook Fujitsu?
http://www.fujitsu-pc-asia.com/drivers/spring05/n3510/audio/winxp/n3510_audio.zip
Hi here is a link copy and paste into top of broswer i know its not the right 1 but ive been on there web site looking for your laptop and could not find it just try to install ok most likey they will be same audio chip find all info at fujitsu hope this helps please rate
Fujitsu Lifebook N3010 boot error
Do you have the original Driver and Application (DAR) CD? If so change your BIOS setting to boot from CD first and boot from the DAR. This will take you to the backup partition DICE (Disk Image Special Addition) on your hard drive. This will allow you to restore your system to the original drive image configuration. You will loose all your data!!!!!!!
Mar 10, 2009 | Fujitsu LifeBook N3010 Notebook
How to remove hard drive from Fujitsu Lifebook N3010 PC laptop
Remove the DVD drive, and then there are 4 outer screws holding the hard drive chassis in place. There are also 4 inner screws that hold the hard drive to the removable hard drive chassis, those do not have to be removed to remove the hard drive from the computer. Carefully remove the screws so they don't fall into the holes on the sides of the screws, and then slide the hard drive out of the pin slots.
Nov 03, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
Fujitsu LifeBook N3010 Notebook Logo
271 people viewed this question
Top Fujitsu Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant  Sharma
Prashant Sharma
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
