4 blinging lights
SOURCE: sony sxrd kds-r69xbr1
4 red blinks indicates a fan error. usually blowing duster inside the fan blades will cure this. there are 4 fans inside this tv. looking from the back of the tv, the large fan on the left side is usually the culprit...good luck to ya
SOURCE: Sony SXRD (KDS-R50XBR1) fan question
there are 2 more fans, 1 is in the middle of the base housing, 2 screws, should be clean. the other is on the left behind the circuit board in a black housing. This fan when i removed it was CAKED with dust and there is no way it could have had any effect on air circulation. the fan is inclosed and you have to take out the whole circuit board to get to it.
SOURCE: My Sony SXRD power led is blinking and the picture
your power supply has failed repair/replace it
SOURCE: replaced lamp on sony 60'' sxrd tv and now get 3 red blinking ligh
I am having the same issue, just replaced bulb not it blinks 3 times. Any ideas?
SOURCE: Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
