Refrakta wake up light
Looking for understandable instructions as I just cannot set this up using the instructions given.
How do I set the alarm on this model, which I cannot find any where. Grateful & puzzled. Model 7-4806A GE Clock Radio
if I could see a good picture of it perhaps I could assist . most have a slide bar to turn the alarm on then you use the hour or minute buttons to set .
Mar 18, 2016 | Audio Players & Recorders
I purchased an RCA Radio/CD player, with the manual showing the numbers RP5605 and RP5605R on it. However, I cannot set the clock, alarm, etc. because everything in the manual's instructions is NOT in
To use the worry-free backup battery, get a 9V battery. Then look for the battery compartment on the bottom of the unit. Press the tab with your thumb and then lift the cover out and away. Plug in the battery and then replace the cover.
Press Wake Time once and use the forward/reverse buttons to set the alarm time. Then press Wake Mode repeatedly to toggle between the options of wake to radio, wake to CD, or wake to alarm. (Note the radio must be tuned to your desired station and a CD needs to be in the player for these to work).
The Smart Snooze means that pressing Snooze, forward, reverse, play or stop will turn off the alarm temporarily. (Pressing Off will prevent the alarm from sounding again today.)
The English version of the manual for the RP5605 clock radio is available here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RP5605.pdf .
I hope this helps.
Dec 17, 2011 | RCA Audio Players & Recorders
Im looking forward to fix my e71 china phone,to used my gprs?i didnt find and understand how to used and fix it,i want to fix gprs to my phone.
those phone the gprs only wakes in china.bt try to take it to your network provider to configer it manualy if they can.
Jul 11, 2011 | Nokia E71 Smartphone
Set alarm clock
goto http://voxrightnow.custhelp.com/app/answers/detail/a_id/12057/~/operating-the-rca-rp4803-clock-radio
or follow instruction
  1. Press the SET button until WAKE 1 / WAKE 2 icon is blinking.
  2. Press REV or FWD to set the wake time. The time decrements or increments will follow by a faster rate when you press and hold either REV or FWD.
  3. After the WAKE time is set, press SET repeatedly until no icon is blinking.
Tips:
  • The unit equips with GRADU- WAKE feature, the alarm tone volume will increase gradually to its maximum in about 30 to 45 seconds.
  • If you set the SLEEP function with low volume level before going to bed, we advise using WAKE mode to wake you up since its volume will automatically increase.
Waking by Selected Source: You may be woken up by WAKE, RADIO or CD.
  1. Select an AM or FM station.
  2. Set wake time (see above directions).
  3. Press WAKE 1 or WAKE 2 to select waking up by WAKE, RADIO or CD. Corresponding indicator will be shown next to the selected setting.
  4. Adjust the volume by turning VOL.
You can select your CD wake track by the following procedures:
  1. Make sure you have inserted a CD.
  2. While holding WAKE UP CD TRACK, press REV or FWD to select your desired CD wake up track.
Mar 18, 2011 | RCA RP4803 Clock Radio
Can't turn off the alarm
There are two alarms, and the steps are the same .
Look on the face. On the left of the big numbers are two symbols, a 'bell' and a 'music note'. That's WAKE 1. On the right of the big numbers are two symbols, a bell and music note. That's WAKE 2. If any of these are on, then one (or both) alarms are set to repeat.
Stopping repeat Wake 1 alarm. Click the Wake 1 button (on the top) several times, while looking at the face. Notice the circles that light up. It will switch back and forth between bell and music note each time you press the Wake 1 alarm button.
HOLD DOWN the WAKE 1 button on the top, until both lights are off. The Wake 1 alarm is now off.
Wake 2 alarm: Same steps, but for the green circles on the right side of the face.
Get a piece of paper, write "HOLD DOWN WAKE BUTTON to stop repeating alarm" and tape it to the back of the clock.
Feb 12, 2011 | GE 7-4853 Clock Radio
May 07, 2010 | GE 7-4853 Clock Radio
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
shows on the display.
2. Press REV or FWD to set the clock
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
This unit allows two wake times to be set.
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
Sep 30, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Need user manual for ge fm dual wake radio 7-4852
so then what are you looking for? instructions on a remote or tv or stereo?
Jan 08, 2009 | GE JASRM24912 Remote Control
Wacky wake up alarm clock instructions
Hold down the "time set" button until the time on the clock flashes. Then use rev or fwd to set the time. Press the "time set" button again once you have the correct time. You can do the same to set the alarm by holding down the "alarm set" button.
Jan 03, 2009 | Watches
Need Service Mode instructions for this mode 1998 model!
With a set that old, it is unlikely you'll get the convergence that close to perfect anyway. You may even make it worse if you go too far in your adjustments. How you could manage to even watch it after looking at a HD set is beyond me anyhow. I would sell it "as is" and stick with HDTV.
Dec 29, 2006 | Sony KP-53S65 53" Rear Projection...
201 people viewed this question
 Grubhead
Grubhead
