Question about Plantronics M50 Bluetoothe Headset
Looks like its dead, when connecting charcher red blinks all the time and nothing happens ?
My headset doesnt turn on, when I plug the charger the red light starts blinking
Could be a combo of low battery and not yet being connected. Charge it overnight and check on it in the morning.
Check out the
Quickstart Guide
Mark
Motorola Support
Dec 31, 2014 | Motorola Mobility H270 Bluetooth Headset
Yellow led blink 8 times compaq m700
I'm not understanding what the problem is. If the battery is dead, and you remove it, how do you expect it to recharge? Why would you remove it? So, you take it out and nothing happens.So? What were you expecting to happen?
Before you do anything more, read the documentation that came with your laptop to learn how to care for your battery. The amber light usually blinks with the battery is running low. When you plug in the A/C adapter, the light usually becomes steady to indicate the battery is charging. At tleast until you remove it.
Hope this helps. Please rate this repsonse
Randy
Aug 31, 2012 | Compaq Armada M700 Notebook
I have a 2003 sony kp51ws500 television and there's a timer on the tv and it won't turn on. A red light blinks 6 times then nothing happens. I unplugged, I hit the reset button, nothing happen
read the instruction manual and see how to operate.
if the timer is for to sleep, the problem will be the IC associates with him, you must see the block diagram and w.diagram. and tracking the signal.
go to www. retrevo.com and download the diagram. God bless you
Jul 31, 2012 | Sony Televison & Video
Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Jun 03, 2009 | Dell Latitude D610 Notebook
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
630 m notebook problem
Sounds like you have a bad jack inside your laptop.  These need to be replaced by a professional, because it requires opening your laptop and soldering a new jack onto the board.
Oct 14, 2007 | Dell Inspiron 630M Notebook
Red Light on nothing else works
recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter to atleast 6 hrs continuously
Dec 01, 2006 | O2 Xda IIs Pocket PC
Plantronics M50 Bluetoothe Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
