Question about Westinghouse Televison & Video
My westinghouse 46" led tv will not turn on, tested the ac power supply and its good
Tv worked fine, then came home and would not turn on, not even the red light at the bottom. tested the ac power supply with multimeter and it tested like it should. my tv is the TW-62401-UO46A. could this be a problem with the motherbaord?
    Top Expert:
  • Westinghouse Master
  • 74,459 Answers
The problem might be of its mother board itself. Contact any experienced service technician to make it confirm before change it. There are so many adjustments should be done after changing a new mother board. It is not a user reparable work.
Posted on Jan 16, 2013
  • 2 more comments
  • saabzach Jan 21, 2013
    i have someone looking at the motherboard. upon opening the back i realized that there is not much else to the tv except the screen and motherboard. would you happen to know any good sites that i could purchase a new one if the motherboard is the culprit?
    and what kind of adjustments would need to be done upon changing the motherboard?
  • The Knight
    The Knight Jan 22, 2013
    The adjustments are not mechanical. All of them are electrical, means by entering into its service mode option. Each and every brand and model TVs today have only this type of adjustments, and the work is a skilled one. You might get an idea about what I'm saying by visiting the site mentioned here. Service mode entry method and adjustments to many brands and models of TVs are described here in detail. If you want to know more, check this site.http://electronicshelponline.blogspot.co...
  • Matthew Conway Jr Jun 18, 2014
    okay people with this tv in particular google it before someone says hay throw it away or change out this part or that this led tv was poorly designed there are two ribbon cables that short out unplug one side at a time testing to see if tv will turn on the power suply for this tv should read 19 dc volts once you take the back off the tv there you will notice two white ribbion cables unplug one side see if tv turns on if not plug the one you unplugged in and unplug the other side check if tv turns on if not unplug oth if tv still dont turn on then assume your motherboard is bad if your tve turns on with one cable plugged in then you have a ad ribbion cable
SOURCE: My Westinghouse w33001 30
the motor on the tv has been tampered with or has been worn out .chances are it could blow up suddenly or damage body parts when it suddleny gives a electric shock so i would advise you to receycle it comment bak
Posted on Jul 09, 2009
freetek
  • 5568 Answers
SOURCE: ESA Plasma PDP4294LV No video,sound
 checked voltages meter set to AC referenced to chassis VA, VE, etc no voltages.
Do not try to measure voltages on the primary side of the power supply with a meter; you may damage the meter and cause new damage to the supply. There are switching frequencies somewhere between 50,000 - 100,000 Hz and possible voltage peaks of several hundred volts.
Checking AC is only useful before a diode bridge that converts incoming AC into raw DC that is then chopped at higher frequency into an approximate HF AC, coupled to the secondary, then tapped and connected to more diodes to produce DC, finally regulated and sent on its way.
Your plasma set uses some higher voltages that could have caused the cracking sound they heard but the DVD player didn't cause the problem directly; maybe just caused the HV for the display to surge for a moment.
You may have additional fuses on the secondary side of the supply. If test points are accessible there, check for DC voltages and be suspicious of any fuse or test point that measures nothing at all.
I can't tell you which voltages to expect since that varies from one design to another but you should find several lower voltages such as 5 VDC for logic circuits and perhaps a 12 V point. The plasma's HV could be produced from a separate board fed from the AC line or get its supply voltage from the main supply. There aren't many standards to rely on here.
The most likely semiconductor failure would be on the secondary side and diodes come in many different packages, many cylindrical, some in the TO-220 package with a metal flange and mounted on upright aluminum heatsinks. These will have only two leads and there will be some in the same package with three legs. The latter can also be checked statically but unless you know what kind of transistor or regulator (look about the same) you are measuring, you will not be able to ferret out a defective one with any luck.
While you have the set open, check for any dust bunnies that can act as sponges, collect moisture and create a discharge path for higher voltages.
Posted on Dec 27, 2008
SOURCE: Westinghouse W33001 Will not power on
I had that happen to my tv and took it to be repaired and it was the power pack where it attaches to the tv it just like snaps on and will arch and burn the power pack and it wont power on so the repair guy charged me $89 parts and labor he put one in but sodered it so it will not draw moisture and arch and it works great now....
Posted on Oct 26, 2008
  • 92 Answers
SOURCE: westinghouse 30" lcd tv has no sound no picture,but green lighton
Replace the Power Supply.
Posted on Sep 06, 2009
barbu51
  • 566 Answers
SOURCE: Working on a friend's LG
Hi syzonker
Before you replace the power supply , check for swollen(rounded top)capacitors.
Also check and replace C126 47mfds/50 volts
And C520 1000mfds/16 volts
good luck and let me know if you need further help
Posted on Feb 16, 2010
Testimonial: "Was getting somewhere with barbu51 when suddenly couldn't reply to him anymore. FixYa said one of his solutions was rated low - BUT NOT BY ME!"
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it
hi. the led tv turn off itseft aroun 5 minutes was complete shut off or another ?? need more data???
Jan 08, 2014 | Westinghouse LD-4655VX 46" LED TV...
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
Westington tv wont turn on
My tv is a Westinghouse**** Sometimes i move the tv slightly and the cord partially comes out at the side and i just push it in all the way and all is ok
Nov 30, 2013 | Westinghouse 46" Class LED-LCD 1080p 120Hz...
Shut off on its own and will not turn back on
if u can get it on for even a couple minutes check the sleep settings and if their on try turning them off see how that helps if not and your still under any kinda warranty call westing house and see how this works
Nov 29, 2013 | Westinghouse 46" LED TV HDTV 120Hz Full...
My westinghouse "46 wont turn on...is it the power supply and can I replace it
It sounds like the power supply is having an issue. Yes its easially replaced no special tools required just a screwdriver. You can get the power supply board from www.tvcircuitboards.com
Feb 10, 2013 | Westinghouse TX-47F430S 47 in. LCD TV
Tv won't turn on Westinghouse ld 4655vx
I just fixed this problem and it wasn't the power supply. I made a video showing how to troubleshoot and repair it.
Feb 01, 2013 | MSI Ac Adapter For Westinghouse Ld-4655vx...
Televison & Video Logo
1,769 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
