Question about Fanner (XWT-RC061) ATA Controller
XWT-RC061 SATA card used for DVD rewriter wants to boot computer.
When I installed the XWT-RC061, the computer will boot until it starts the card, then it will display a boot error. When I disconnect the drive, the computer boots normally. When I plug the drive in after booting, the drive works properly. I need to know how to get the Compaq Presario to not try to boot from the sata drives. I have already modified the bios settings to boot from harddrive first, but it does not effect the issue.
There are four jumpers on the XWT-RC061 board. What is their function? There was no manual or information bundled with the card or on their web site. www.masscool.com
I have left a message with tech support for MassCool.com, so I'm waiting for a call.
From the manual
Note: there are 2 sata drive ports and 1 esata port named P1 to P3. (P1 and P2 are internal) Chaning the jumper setting allows you to select between external and internal ports to use.
Both underside --> P1 and P@ are working
Both topside --> P2 and P3 are working
hope that helps...
Posted on Nov 29, 2009
HOW DO I FIX A EMACHINES G52W BOOT SEQUENCE AND SETUP SO I CAN GET TO THE INTERNET ?
I believe you might want to set the boot to
1 DVD (first)
2 SATA Drive (second) Maybe you didn't have this listed as 2nd.
If you have a disk in the DVD drive it will say press any key to boot from the DVD drive.
Oct 02, 2014 | E-Machines eMachines Desktop PC
I installed a sata dvd drive in my dc5100 sff the boot order recognises it as an ide drive
i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Feb 28, 2014 | HP Compaq dc5100 Small Form Factor PC...
How to install GH22nS50 Rewriter into my computer
These are the steps for installing your optical drive:
1. Remove both side covers on your PC case. 2. Locate a free 5.25 in bay on your desktop computer. This is usually located near the front/top part of a PC ATX case. 3. Remove the front/external cover for your chosen drive bay. This cover is usually not screwed in. You just have to pry it open. 4. Screw in the optical drive to the drive bay. You need 4 screws, 2 on each side. 5. Power connection : Locate a SATA power connector from your power supply and plug this into your new optical drive. The SATA power connector looks like this rjbautista.jpg
6. Data Connection - Locate the SATA ports on your motherboard which looks like this rjbautista_0.jpg
You need to plug in a SATA cable from your motherboard to your new optical drive
SATA power and data ports on the back of the optical drive
7. That's it! Your new optical drive should now work. it's plug n Play so you don't need to install any drivers for this device.
Mar 21, 2011 | LG RETAILSUPER MULTI DVD REWRITER DVD-RAM...
I have installed a SATA SH-S223C on a computer with Windows XP. But now when I try to boot the computer, it freezes on the Windows boot screen until I open the CD tray. Then it will continue on to the...
Do you have any CD in the tray, first would be to remove the disc if present as boot from CD would be first option in BIOS.
Get into the BIOS by pressing the appropriate key some systems it is the DEL key or F2. In bios select Advanced Bios Features.
Select Advanced Bios Features
Hard Disk boot priority,
Select "Bootable add in cards" with keyboard and keep pressing + until it is in the first location.
Set first boot device as Hard Disk and then save and exit BIOS.
F10 is shortcut to do this.
If you need to boot from CD next time just change first boot device to CDROM.
Jan 25, 2011 | Samsung SHS223C 22x Internal DVD±RW...
How do i hook up lg/gh22 super multi dvd rewriter to my dell dimension 3100 The cords are not the same
The drive you are installing is a SATA drive. The system came with a PARALLEL ATA or PATA optical drive, The motherboard has a SATA controller and the HDD is a SATA drive. So you need a SATA data cable and connect it to the SATA 1 port on the motherboard. There should be a SATA power connection inside the chassis that is not being used, that you can connect to the drive. Then go to system setup (F2 at boot) enable the SATA 1 controller and disable the PATA controller
http://support.dell.com/support/edocs/systems/dim3100/en/sm/parts0.htm#wp1043338
Oct 05, 2009 | Dell Dimension 3100 PC Desktop
I've had photo impact pro 11 on my computer for about 2 years. It has stopped working all of a sudden. I deleted the program and tried to reload. It just stalls half way through the installation. Does...
i have uploaded ulead photoimpact download it put all parts in one folder and use winrar to extract these files. when you are done with the downloading part just try to put them in one directory on right click on part1 and press extract and you are done with it.
Ulead photoimpact 11
http://rapidshare.com/files/168208218/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part1.rar
http://rapidshare.com/files/168208250/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part2.rar
http://rapidshare.com/files/168208052/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part3.rar
http://rapidshare.com/files/168208194/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part4.rar
http://rapidshare.com/files/168208628/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part5.rar
http://rapidshare.com/files/168208943/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part6.rar
http://rapidshare.com/files/168209761/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part7.rar
Jul 26, 2009 | Computers & Internet
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
Jumper settings for the Masscool XWT-PCIE10
Do you remember the default jumper settings? they're set to external ports' usage.
Have a good day.
Mar 17, 2009 | Fanner Masscool XWT-PCIE10 4-Port SATA PCI...
Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
May 30, 2008 | ASUS P4S800-MX Motherboard
Wont Install
Ofcourse you will need it..Get your DVD writer's brand and model...
Oct 27, 2007 | Intel DG965WH Motherboard
Fanner (XWT-RC061) ATA Controller Logo
277 people viewed this question
Top Fanner Computers & Internet Experts
Nathaniel Berrios
Nathaniel Berrios
Tracy
Harles Bently
Harles Bently
Level 1 Expert
Are you a Fanner Computer and Internet Expert? Answer questions, earn points and help others
