Question about Electrolux EOD6330 Ultrafan Electric Double Oven
Top oven/grill. Element has dislodged from the screw connection. Attempted to screww back the element and there seems no thread for the screws to attach to the oven. What are my options?
Tried screwing back. The screws are not connecting to any thread.
  • Official Brand Answer
  • 4,342 Answers
Hello Michael Clift - I am happy to assist you. First, I will need your model number (and serial number if you have it) to better address the issue at hand. Thank you.
Posted on Jan 22, 2013
3 Suggested Answers
  • 1214 Answers
SOURCE: replace the grill element in electrolux EOB847 fan oven
Yes, you do have to access from the back side.
Posted on Feb 14, 2009
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Posted on Jul 08, 2009
Top element (grill) dropped. Screws no longer holding
get new screws for it to hold up
Jan 20, 2015 | Ovens
The element in the top oven/grill just fell down, tried to re screw but feels like there is nothing for the screws to attach themselves to.
The only solution here is to use the largest self tappimg screws you can find to secure the element to the oven top as the metal has corroded away.
Nov 16, 2010 | AEG D2100-4 Electric Double Oven
Zanussi built in oven and grill the element has gone but dont know how to get element out to replace any ideas thanks
If you mean the fan element then take all the racks out of oven and at the back is a panel with 4 screws remove may need a tap with hammer and screwdriver to shock rust etc. then undo screws on element maybe 3 screws pull gently forward(electric off).Try to pull the spade connectors off without losing them into back of oven if you lose them then you will have to take out oven and remove back plate. refit new element.If it was the grill element just follow above and find behind back plate.Hope I helped.
Apr 11, 2010 | Zanussi ZBF360X Electric Single Oven
The grill element has fallen down because the two
What you need to do is obtain 2 large self tapping screws,and resecure the element to the top that way, or failing that , fit 2 cavity wall screws, these will also do the job, but you may have to enlarge the holes.
Apr 06, 2010 | Zanussi ZDQ695 Electric Double Oven
How to replace the grill element in a Stoves 720EF double oven?
1) Isolate the unit by turning the power off at the main switch.
2) Remove appliance from housing unit.
a) When handling the appliance care should be taken to ensure the outer frame trim is not damaged.
b) The appliance is secured into the housing unit by 2 screws through the top corners of the front frame, open the doors and unscrew the 2 corner screws.
c) Grasp the bottom of the frame, pull forward and out onto a suitable surface.
3) Unscrew the top and rear panel securing screws and lift the panels clear.
4) From the rear of the appliance, pull off the 4 (top) grill element leads and the earth lead.
5) From inside the oven unscrew the 2 screws from the grill mounting plate.
The above is from the Handbook. I assume from point 5 the element is then free to be removed. reverse the procedure to fit the new element.
If you want a copy of the Handbook, then I will need an email address for you.
Mar 11, 2010 | Stoves 720EF Electric Double Oven
Can I change the grill element myself? I assumed it just plugged in at the rear and have removed the two screws holding element to top of oven. Now I wonder if the steel plate at the back is itself bolted...
The grill element is not usually a 'plug-in' device.
You will have to remove the back of the oven/grill and disconnect it from the back before you can withdraw it from the front.
Remember to switch off the power before removing the back.
Jan 12, 2010 | Bosch HBN 131560B / 131520 hot-air...
How do you change the grill element ? on a Neff U1421N2GB/05
screw at top of element is for support.. there are either 2 screws at the rear of element bracket holding it or access to behind the rear panel is required as there are 2 nuts holding the grill bracket to rear cavity. please make sure power has been disengaged before attemt to repair..
Dec 21, 2009 | Neff U1421 Double circotherm Electric Oven
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 | Ovens
I have a FX4942U1/1 oven and the top oven/grill element has just gone. I can buy one online at £12.99. Is it possible to fit the element or would I need to employ an electrician to do it?
remove two screws that hold element into rear of oven after unplugging oven power source and either the element has screw terms or push-on connectors
Nov 01, 2009 | De Dietrich UMP404 Powerclean Stainless...
Hotpoint built in oven top grill element renewal
yes they are - two nuts on posts that stick out from the base plate plus one screw inside oven opposite the base plate
Sep 09, 2008 | Hotpoint Ovens
Electrolux EOD6330 Ultrafan Electric Double Oven Logo
90 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
