Question about Panasonic KX-T7730 Corded Phone
I have a panasonic kxt7730 corded phone, when the door phone rings, I see on the display door phone 1, but I am not able to answer the door phone. It worked before, but I don't know what I did th
  • PLEASE PLEASE help me with a solution PLEASE PLEASE PLEASE
3 Suggested Answers
consultel1
  • 860 Answers
SOURCE: I work for the Western Regional Day Report Center
Check to see if the ringing volume is turned down,
On the base unit press the menu button and scroll to ringer settings using the up and down arrow keys, press the enter key.
Scroll down to ring group and press enter.
Press the left or right arrow keys to select the line desired.
press the down arrow key to move to Ext #.
Enter in the disired extension number starting with the base as Ext 0.
press enter to save.
Posted on Apr 05, 2010
SOURCE: my Panasonic KX-TG2361JXB cordless phone answering
I NEED MASTER PASSWORD OD CORDLES PANASONIC..KX-TG2361JXB
Posted on Jun 05, 2010
CO problems
Check your Phone if connected to Jack 01 to do programming below:
on KX-T7730 phone Press Program *# (enter Password) default is 1234
Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
Dec 04, 2013 | Panasonic KX-T7730 Corded Phone
I need panasonic telphone model no KXT7730
A 7731 and 7730 are interchangeable, as well as the 7735 and 7736. All 4 models are display phones and only differ in the display size and how the buttons light up under the dial keypad.
Carl
Sep 05, 2011 | Panasonic KX-T7730 Corded Phone
I want to see the phone number of prson that called me and i answer him. KXT7730
Your Panasonic System display phone is capable of showing CID if you have a CID card in your TA/TD/TAW or higher series phone system and have done some programming. The card part number ends in 93 and installs inside the cabinet for the particular system. After the card is installed, programming turns it on to tell the line to wait for the CID string before ringing the phone.
Your phone also has to be ringing or you won't see CID until you answer the call.
Carl
Apr 03, 2011 | Panasonic KX-T7730 Corded Phone
How can i active or desactive the FWD/DND in the model. KXT7730?
it really depends on your phone system
but the possibilities are:
1) "INTERCOM"
2) *710
3a) 0 to deavtivate
3b) 5 to set to busy/no answer
4) put the number you want to fwd to then "#" *confirmation tone*
or
1) "INTERCOM"
2) 710
3a) 0 to deavtivate
4) put the extension number you want to fwd to *confirmation tone* (extension number only)
Jan 03, 2011 | Panasonic KX-T7730 Corded Phone
I need to have our Panasonic KXT7730 to ring at reception but instead one of our lines rings on another phone in another room. How can I change it to ring at reception.
Hello, I presume that you are using this phone on a 308 or 824 system. You will have to check which line is ringing at the other phone. Is it line 1,2 or 3 ? Say for example it is line 2 you need to do the following: From the main phone / switchboard usually ext 101 press PROGRAM * # and your system password ( default is 1234 ). Now enter 408 and press SP-PHONE. The system now asks you to enter the line and in this example we use line 2 - so enter 2. The display now looks like this CO 2:#01: with ENABLE or DISABLE flickering. (CO 2 is the line number. #01 means extension 101, #02 means ext 102 and soforth.) To enable the line to ring at ext 101 choose ENABLE by pressing the AUTO ANS / MUTE button. Now press AUTO DIAL / STORE to save your changes. Now use the right arrow key ( located at the right bottom corner of the phone ) to move to the extension that you don't want to ring - say for example 106. Your diplay should now look like this CO 2:#06 with ENABLE flickering. Now use the AUTO ANS / MUTE button to set it to DISABLE and press AUTO DIAL / STORE to save your changes. Press PROGRAM to exit program mode.
PLEASE VOTE / RATE MY ANSWER IF THIS WA HELPFUL - THANK YOU.
Feb 08, 2010 | Panasonic KX-T7730 Corded Phone
Lost password kxt7730
Hi i am trying to change the name of a extension in my kxt7730 but it asking me the code i already use *#1234 and **1234 but it didnt work, i will like to know if its a way to reset it thank you
Dec 10, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7453 default answer ringing line
Craig From the Idle phone, press PROG 20 ENTER then SEL until the display says Ringing Key and ENTER. Press EXIT to end.
Carl
Sep 19, 2008 | Panasonic KX-T7453 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
48 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
