Question about RCA RCR311B Remote Control
Sky remote code for kishu - RCA RCR311B Remote Control
Sky code for a kishu 32 led tv it's driving me mad !!!! Pls help !!!!
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jun 07, 2016 | Televison & Video
What is the code for a Ferguson TV
Ferguson tv sky remote codes ' AVForums
www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
Sep 24, 2014 - Hello, does anybody know what the sky remote control codes are for aferguson television. I have tried to find the solution on the internet but the... Sky Remote Code for Ferguson TV
Sep 28, 2014
Sky code for Ferguson Tv
Apr 22, 2010
More results from www.avforums.com
Remote Code For Ferguson TV - Sky - Digital Spy Forums
Dec 15, 2015 | Televison & Video
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Dec 17, 2010 | Televison & Video
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
I NEED A CODE FOR SKY REMOTE
Hi.
Here available codes for Sky Remote: sky remote codes
Nov 05, 2009 | Televison & Video
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Televison & Video
Pin code for wharfedale tv
1 am looking for the sky remote code for a wharfedale ltf42k1cb teley
Oct 18, 2008 | Televison & Video
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
RCA RCR311B Remote Control Logo
44 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
