Question about Craftsman Air Tools & Compressors
3/4 inch impact will not stop turning - Craftsman Air Tools & Compressors
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
Won't stop turning
A very common fault on this model is the throttle valve seal (item# 28) wear out or falls apart.
First verify that the trigger is not binding.
Second look inside the inlet bushing (item# 49) and see if the screen (item# 51) is in place, if missing debris from the air line can cause the throttle valve (item# 29) not to fully close.
For removal you will have to punch out (item# 50) spring pin, then the inlet bushing (item# 49) will slide out and the other parts will follow.
Follow this link to view the parts list:
http://powertoolrepairohio.com/pages.php?pageid=14&breakid=500
Jan 25, 2013 | Chicago Pneumatic CP776 3/4 Inch Super...
How do you get the pulley and nut off on the cutting pulley to change it?
The easiest way is with an impact tool. It will spin the nut faster than the shaft can spin and will remove it very quickly. If you do not have an impact tool, then you will need to stop the shaft from turning. Put a large clamp onto the under side of the deck and then rotate the blade around against it. This will stop the shaft from turning while you remove the nut. If you have already removed the spindle assembly from the deck, you will have to clamp the lower end of the shaft in a vise to be able to remove the nut. It should be a standard threaded nut, which will remove when turned counter-clockwise.
Sep 11, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Nov 14, 2009 | Craftsman 1/2" Impact Wrench
Craftsman 1/2 inch impact air driver leaks air
put a bunch of hydraulic oil in it and this will lubricate the seals inside to form a more uniformed seal it will stop leaking air.
Sep 03, 2009 | Air Tools & Compressors
Windage and elevation not working barska 8-32*50mm
I doubt if there is anything wrong with your scope.
The Baraska model A10810 Reticle adjustments are 1/8 ( 1/8 inch) MOA (minute of angle).
For instance, Look at the top turret (The ELEVATION Adjustment Knob). You will see that there are little vertical 'hashmarks' all the way around the knob starting with a '0' then a series of the verticle hashmarks, then a '1' and another series of the marks, then a '2' and so on. YOUR scope will have 8 of those vertical 'hashmarks' between each 'number'. These little 'hashmarks are referred to as 'Clicks' or 'Minute of Angle' adjustments.
Now imagine that you are set up on the 100 yard line and you have fired a round at your target, say a one inch diameter dot or any size for that matter, and the bullet strike was one (1) inch LOW and two (2) inches to the RIGHT and of course you now want your next round to impact in the target dot.
To bring your bullets point of impact UP to coincide with your point of aim (you have your 'crosshairs or RETICLES centered on the dot), you will be turning the TOP adjustment knob CLOCKWISE, ONE 'click' at a time. EACH one of those 'Clicks' will actually move the horizontal Reticle UP (Elevation) or DOWN 1/8 of an inch at a time. If the bullets point of impact was 1 inch LOW, you would need to turn the adjustment knob clockwise Eight (8) clicks which will equal ONE (1) inch.
Now you must adjust the knob on the RIGHT side of the scope. This one is the WINDAGE Adjustment knob which controls the VERTICAL Reticle and moves the point of impact Right or Left. This knob will also have the 'hashmark' increments around its perimeter and like the Elevation knob each 'Click' will move the Reticle 1/8 of an inch but in this case the Reticle and point of impact moves Right or Left.
Remember the bullets point of impact was 2 inches to the RIGHT. This means you must adjust the Reticle or point of impact to the LEFT so that your point of impact will coincide with your point of aim and will be in the target dot. Turn the adjustment knob COUNTER CLOCKWISE Sixteen (16) Clicks. Keeping your POINT of AIM (crosshairs centered on the dot), your next round should be inside the dot and you can then fine tune it from there.
As you can see from this example, the Reticle (crosshairs)and point of impact does not travel very far at all inside your scope at the 100 yard distance so it is not hard to imagine that you thought they were not adjusting to get you on target, when in fact they WERE adjusting, but in tiny increments.
Now, as you create more distance between you and your target, these 'tiny' increments and point of impact will be larger as your distance increases. For example, at 200 YARDS each 'click' will move your Point Of Impact 1/4 of an inch right,left,up, or down. So if your bullet point of impact was one (1) inch low from the 200 yd line you would adjust your Elevation Reticle 4 Clicks to raise your point of impact in order to be on target. At the 300 yd line each Click will adjust the point of impact up,down,right or left, ONE (1) inch.
If you wish, I would be happy to walk you through the 'ZEROing In' of your scope and rifle even if you do not have a Zero Bore Scope. With-in about 9 rounds you can be hitting where you are aiming instead of 'chasing' bullet holes all over the paper.
If you are interested, respond back and I will be glad to assist you. Enjoy. :)
Apr 07, 2009 | Optics
I am looking for a carbon brush housing replacement part for an AcDelco 1/2 inch Electric impact wrench Model # AC-PT012 can you help?
You can buy at Nappa auto parts stores. Please rate as this is a short answer and if you don't rate it it hurts me.
Feb 19, 2009 | ACDelco AC-PT012 7 Amp 1/2-Inch Impact...
Air Tools & Compressors Logo
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
