Question about Flotec 1 Hp Deep Well Pump
My pump comes on but will not kick off until i tap the top of the regulator box. I also see a spark back there every once in a while
Model c48k2ec15 convertible hydroglass. This is a pump that sits on top of a pressure tank in the basement. 1hp
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
  • 89 Answers
SOURCE: air in lines
SOUNDS LIKE A CRACKED SUCTION STUB OR LOOSE THREADED FITTING SUCKING IN AIR.
OR THE CHECK VALVE IS FAILING AND ALLOWING THE WATER TO LEAK BACK SLIGHTLY OR ALL THE WAY BACK. YOU CAN ALSO ADD A FOOT VALVE AT THE END OF THE PIPE.
LONG SHOT, BUT THE BLADDER TANK IS CHARGED WITH AIR AND MAY HAVE A HOLE IN THE BLADDER CAUSING THE TANK AIR TO ENTER THE SYSTEM. SHOULD RUN OUT QUICKLY THOUGH. HOPE THIS HELPS, JODY
Posted on Jul 19, 2009
  • 165 Answers
SOURCE: Installed a new jet pump for shallow well (gravity
The pressure tank must have a certain amount of air in it so pump doesn't cycle as you say. The new pressure tanks have a bladder that separates air from water and keeps the pump from cycling so much. Make sure your pressure switch on the pump is OK--ie doesn't have burned contacts!
Posted on Mar 01, 2010
aquaman987
  • 927 Answers
SOURCE: The pump operates, but will
It is possible that sediment has clogged the opening that supplies the sensing pressure to the switch. Shut down the pump, open a valve to drop pressure completely, remove the tube where it enters the pump body and stick a small wire just into the hole, once that is clear, see if you get water to come out when the pump is activated. Next, you can see if the entire sensing tube is clear by disconnecting the end on the pressure switch and ensuring flow there. Lastly, make sure there is nothing plugging the inlet at the pressure switch. This has a rubber diaphragm in it, so do not stick anything up inside, just ensure that there is no rust/corrosion in the inlet area.
Posted on Dec 27, 2010
aquaman987
  • 927 Answers
SOURCE: I replaced old pump w/
The water and therefore the pressure has to be going somewhere. If you are sure that there are no leaks in the house or outside, then the water is going back into the well. There is a check valve either in the suction line of the pump between the top of the well and the pump or down in the well.
If this check valve fails, it allows water to go the wrong way and back to the well. The result is that you lose pressure.
Secondly, you have to be sure that there are no air leaks between the top of the well and the inlet to the check valve. Leaks in that piping will make repriming difficult.
Write back with more and I'll try to help more.
Gary
Posted on Jan 22, 2011
How do you change in tank fuel pump on 02 model
Depends what car or truck. Some cars you can get to the fuel pump under the back seat or cargo space or drop the tank. On some trucks it's easier to pull the bed off then dropping the tank but may need to do both. When they build these autos they don't consider how the shop guy to fix them.
Feb 11, 2018 | Cars & Trucks
There is spark and fuel up to rail but injector wont come on
sounds like the injectors are not getting a signal to squirt or no fuel . Have a pressure test done on the fuel manifold to check pump, pressure regulator pressure and filters.. check injector connection to ECM
Dec 24, 2013 | 1997 Mercury Cougar XR7
Bike wont start
Check the fuel tap is turned on and that the fuel filter is clean. If this is all good, you should check that fuel is getting into the fuel reservoir on the carb. If no fuel is getting through, your fuel pump may have failed. But, as you don't say the make and model of your bike, I can't be sure.
May 17, 2013 | Motorcycles
I have a 2002 buick rendezvous I am have trouble with the fuel delivery it's not getting any power back to the fuel pump we had it started when we ran a wire to fuse box and ran it strait to fuel pump...
check the pressure regulator and wiring
some models use the regulator to notify the ECM that pressure has been reached so the ECM cuts off power to the pump relay until the pressure falls
Apr 13, 2017 | Cars & Trucks
Cold start problem mazda 2001
Could be the fuel pump relay, or a faulty pump, or pressure regulator.
The fuel system is supposed to hold pressure after you turn the engine off. A faulty pump or pressure regulator could allow fuel to drain back into the tank overnight. You would need to crank the engine for several seconds to build pressure back up.
The relay could be faulty and not giving the fuel pump power until the oil pressure comes up.
Dec 08, 2012 | 2001 Mazda Protege
My Kawasaki fury is not starting after 2 days of rain.. Can you help me identify possible solutions to my problem?
its also my problem with my fury 125, drain the fuel in the carbureutor unscrew it until water will come out,, once it changes to red or green screw it,, then kick start it will be ok,,, or unplug the spark, clean it then kick without the spark plug to squirt out all the dirt or water then put the spark plug kick start vroomm,,
Aug 10, 2012 | kawasaki Motorcycles
Spark plug replacement
REMOVE THE TOP COVER, PULL THE RUBBER CAP OFF THE TOP OF THE PLUG, TAKE A 19MM BOX SPANNER AND TURN THE SPARK PLUG ANTI CLOCKWISE UNTIL IT COMES OUT, R FIT THE NEW PLUG GAPPED AT 0.5MM BACK INTO THE CYLINDER, TIGHTEN CLOCKWISE UNTIL SNUG.
Jun 11, 2012 | Poulan Garden
Honda blackbird 2002 not starting , it is cut off somewhere
check the fuse at the fuse box, 2nd check the spark plug might be wet @arcing clearnce, if it has kick starter you may try to ground the detached terminal cap of spark plug if it arc as you kick the starter, good, if not fuse busted no supply to the cdi(regulator)
May 22, 2012 | 2002 Honda CBR 1100 XX Super blackbird
Spark plug loaction 2004 trail blazer
Remove the resonator box on the top of the engine. You must disconnect the intake air tube and the connection to the throttle body. Be aware that there are two connections to the airbox resonator. One for the fuel pressure regulator (If the 04 model still has that) and the PCV hose. After this is off it will reveal the coil packs (6) on top of the motor. Carefully remove the two bolts that hold the coil packs down. They are long and thin so a tap with a hammer on top is sometime a good loosening move. The pLugs should be good for 100,000 miles. Be sure that it is not a coil pack that has gone bad before wasting money on the plugs.
  1. 4 tends to get water on it durring heavy rain if your hood seal is bad and you are parked on a slope.
Once the coil pack is removed the plug will be easily removed however they are inside the well.
May 27, 2010 | 2004 Chevrolet TrailBlazer
The fuel pump is not pumping the fuel.
Is the fuel pump actually coming on??? If it isn't, I would start by checking for a fuel pump relay.  This is usually located up in the engine compartment in a black box on the drivers side.  Relays are small black boxes approx 1"x1".  These have a tendency to go out just like fuses.  Also double check your fuses.  If you suspect a that a relay is bad, you can interchange them with other relays that look the exact same to see if they really are the problems.  These relays are very quick and easy to change and are very cheap.  They usually run no more than $10-15.
Any further questions, feel free to ask.
Feb 03, 2009 | 1995 Chevrolet Lumina Apv
Flotec 1 Hp Deep Well Pump Logo
37 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
