Question about Video Cameras
How do I open my Bright Pink Cupcake Tape Dispenser from Staples to put a new roll of tape in?
Can not open the dispenser to reload tape.
    New Friend:
You have to shove your finger down to the bottom where there are two latches you have to pop out. They are on the bottom, closer to the front of the cupcake. good luck.
Posted on Sep 08, 2014
  • Frank Sanchez
    Frank Sanchez Oct 01, 2014
    Thank you, that really did the trick!
silly girl
  • 513 Answers
SOURCE: Sony Handycam DCR-PC1E
I'm not from the UK so can't help you find a lab. but regarding your problem - The fact that it works well without a tape tells us that the load motor and possibly even the capstan motor and associated mechanisms are working. It doesn't tell us much about anything else though. Could be that the head drum is not spinning - This can be the result of a siezed drum motor, or power supply fault(if seized it will draw excess current, thus giving a battery warning indication). A faulty, or possibly even a correcly working dew sensor - This will allow the heads to spin, but prevent the tape from actually lacing up. This is a 'hard' one really, because if the dew sensor is faulty you will get this problem, but you will get the same problem when the sensor is working and actually doing its job in that it has really detected moisture. There are many other possible causes too. The first thing to look for is to see if the heads are spinning - or at least see if they *try* to spin, because unless they *are* spinning the tape will never load. Also, the heads *shouldn't* be spinning with no tape inserted - if they are then this suggests that the dew sensor has been activated (the heads are made to spin under this condition in an attempt to dry things out). If this gives no clues, the next step would probably be to dismantle the thing and attempt to load a tape by hand (looking for signs of jamming mechanism, etc. Anything more serious than this is one for the workshop. Platano guatemalteco? Good luck!
Posted on May 29, 2006
Gryfox
  • 216 Answers
SOURCE: Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
Posted on Dec 18, 2006
  • 883 Answers
SOURCE: Eating Tape when rewinding in vcr mode
look for a tiny pinhole and insert a pin while powered up to reset the device. if no-go, then the take-up reel needs attention...needs possibly a new or well-cleaned-with-alcohol-swab rubber belt
Posted on May 27, 2007
  • 883 Answers
SOURCE: Tape wouldn't eject, now power unavailable.
open it. find the motor that activates the tape door. turn it by hand until tape is fully exposed to be removed.
Posted on May 31, 2007
SOURCE: stuck tape in camcorder
I had a similar problem with an older panasonic camera. Mybe you have tried this, but opening the door and pushing up on the tape. Push in and use enough force but don't try to break it. Try pressing different spots. Sooner or later the motor might start moving it up. Just a though, it worked for me.
Posted on Jun 07, 2009
How to change the tape roll
Facing the dispenser with the cutting edge pointed toward you slide the axle to the left
Nov 26, 2013 | Staples Executive Desktop Tape Dispenser,...
How do you open a Scotch Tape Dispenser C60 to change the tape
The entire carriage lifts out using a good amount of lifting force. Slide your finger under the empty roll from the front of the dispenser. Apply upward pressure. You may be concerned that you will break the plastic roller, you won't. the entire carriage will pop up. When it does it's a simple matter to replace the old tape with a new roll. Snap the carriage back into place to use the new roll.
Jan 21, 2013 | Scotch C60 black 2 Tone Desktop Tape...
The soap dispenser door will not open. How do I remove the top of the washer to access the soap dispenser? I know that the blue plastic piece for the fabric softener lifts up when I try to pull open the...
To remove top: Remove the bottom screw from the plastic clips on back of the washers top. next, stand in front of machine and, using the palms of your hands, sharply push the top back about 2 inches, allowin you to lift the top off.
Dispenser issue: you may have to drill a small hole in the plastic top of the dispenser to allow you to push the offending part down while pulling on the drawer. seal the hole with silicone or foil tape.
Feb 20, 2011 | LG WM-2277HW Front Load Washer
I wasn't able to pull all of the white tape surrounding the staples out when I loaded the staples. Now, the copier is saying that we need to load staples. How can I open the holder to remove the tape?
You have to be careful. Remove the bottom of the cartridge by releasing the four clips that hold it on. Make sure you put the little lever looking part in correctly when you reassemble. This is how the finisher determines the out of staples indication. Remove the staples and put them back in with the arrow aligning with the clear arrow on the cartridge.
Oct 29, 2010 | Canon imageRUNNER 5570 Copier
Reloading tape roll on a Casio DR-T120
place the paper sticking out of the top, then close the cover. it will start working; good luck
Jun 02, 2009 | Casio DR-T120 Calculator
Place the tape between the two posts; then put back portion of cover down followed by the removal front portion - press feed button and it should feed. Remember it will only print on thermal paper ----
Dec 08, 2008 | Casio DR-T120 Calculator
Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Oct 11, 2008 | LG WM-2277HW Front Load Washer
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
ICe does not fall from KitchenAid KSCS25INSS00 Ice Dispener
remove the bottom tray that you sit your glass on, push down on the bottom of the trim arround the despenser, lift outward then upward on the trim panel, have a piece of duct tape handy to tape the panel out of your way to gain access to the assembly
Jan 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Video Cameras Logo
2,544 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
