Question about Panasonic SA-HE90 Receiver
How to conect speakers - Panasonic SA-HE90 Receiver
If speakers of 10" tablet blow who will fix it and how much does that type of repair cost ?
it depends from speaker used in tablet..if it is from china market the speaker cost max 5$..you can replace the speaker it is conected with wires just cut the wires and conect the wires from new speaker..you can find the speaker on ebay
Feb 26, 2015 | Tablets & eReaders
Kdc-bt30 turns on plays for a couple of mins then powers itself down and will not restart for a few mins
How many speakers did you conect to it? This looks like the autoprotection is turning off your system due to a overheating in the final transistors. When they cool down the system can be played again. Verify with the owner's manual what is the impedance of speaker accepted by the system's amplifier. Measure or calculate the resistance of your conected speakers on each channel. If they are conected serial the formula will be Rtotal=R1+R2+R3+R..... If connected in paralel Rtotal=R1*R2*R3*R..../R1+R2+R3+R... Where Rtotal is the value wich you have at head of the wires in the conector to the Playe/amplifier, and R1, R2, R3, R... the value of each speaker.
Jan 27, 2011 | Car Audio & Video
Speaker conections have a black and white wire for the conections does it matter how they go on?
It doesn't really matter.DC V is DC V and does not really have a polarity issue.The current can flow either way with the same result.
Aug 12, 2010 | Sony XS-L100P5H 10" 4-ohm Component...
What's the name of speaker conector of the HT Samsung HT-Z320
They are called composite video and audio connections. (RCA jack style)
May 29, 2010 | Samsung Audio Players & Recorders
How to conect the speaker to the computer? I got the monitor and a friend gave this kind of speaker but I don't find the conection betwen the computer to the screen, have the wire but Ican't find the...
To connect your audio system to your pc do the following:
Step 1. Take the two-pronged cable that plugs into the "Out to PC" and locate the green and pink cables.
Step 2. Plug the green audio end and plug this into the Headphone (line out) jack on your computer.
Step 3. Take the pink audio end and plug this into the MIC jack on your computer.
May 01, 2010 | Boston Acoustics BA745 Computer Speakers
4ohm speaker connected a normal 8ohm crossover is
This is a wrong conection.For 8ohm crossover conect two speakers in serie and one in parallel to one of a previos.Check resistans by multimeter
Dec 02, 2009 | Parts Express 80 Hz LOW PASS 4 OHM...
My speakers arent working, also saying there is no driver installed please help.
Well first of all you ned to see if the speakers are ok y can acheive this by placing two wires onto a 1.5 volt battery and listen for a crackle depending on the conection you might have to tape the wires to the conection to start with on on the bottom of the 3.5 mmjace and one near the top fo the jack around the side dont let them touch otherwise it wont work if you do hear a cracle when you conect the battery then the speakers are working or trry a diffrentset of speakers on youre computer and se what happens
Nov 22, 2009 | Logitech X-530 Computer Speakers
Speakers conect to tv
Yes, as long as you can plug it in, it will work.
If you have any more questions, please feel free to ask.
Dec 19, 2008 | Labtec Pulse 285 Computer Speakers
Speakers conection
Buzzing
bad amplifier or input has bad ground conection or positive conection
can you describe if its only one side or comming out both?
Oct 16, 2008 | M-Audio StudioPro 4 Main / Stereo Speaker
Panasonic SA-HE90 Receiver Logo
26 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
