Question about Home
What makes automatic hand dryers turn on? - Home
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
The new dryers have a motion sensor. It turns on when it detects your hand and then turns off when your hand goes away. This way it saves electricity by not continuing to run once you're gone (like the old automatic ones did).
Posted on Jan 16, 2013
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
My whirlpool electric dryer makes a loud grinding noise
Is there anything caught between the dryer drum and any housing. Can you hear it when the drum is turned by hand.
Jan 26, 2014 | Whirlpool Dryers
I cleaned the vent but it still takes to long to dry
if it is heating well, then you have a ventilation problem,make sure lint trap is clean if so disconnect dryer vent hose from dryer turn dryer back on put your hand where vent is make sure good hot air is comming out if so dry a load of clothes without vent tube connected,they should dry in a normal amount of time ,if so then your dryer hose is either bent too much or collasped,if hose looks good then it will be vent leadinding outside you can take a leaf blower and put in vent and blow it out,your dryer either vents on the side of the house or the roof turn dryer on put your hand on exterior vent make sure air is coming through
Jan 23, 2011 | Dryers
My electric dryer has heat but will not start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Apr 19, 2010 | Windchaser Automatic Electric Wall Mounted...
Bosch WTMC3500UC Gas Dryer Dryer...as it is turning makes LOUD clanging banging noise. Will make the noise when turned by hand does not make the noise when tuned by hand in the other direction.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
gkjlgkj
Feb 15, 2010 | Bosch WTMC3500UC Gas Dryer
Dryer doesn't want to run- makes grinding noise
its sounds like a worn bearing problem.with the m/c switch off ,turn drum by hand and see if it is hard to do so.if you get a gritty feeling in your hands or hear a grinding noise,then that is probably the bearing.
Jul 23, 2009 | Dryers
Dryer tries to start but drum wont turn
You can turn it by hand but make sure it is unplugged!!
Jun 28, 2009 | Maytag LSE7806A Top Load Stacked...
Kenmore 90 series dryer makes noise and does not want to turn. I can make it spin by hand holding the door switch in, grab it and spin it, and get it to spin again. It keeps doing the same thing when
Your motor is worn out. Bearings worn and not enough power to start it. Motor is not repairable it must be replaced or new dryer. Sorry
May 20, 2009 | Kenmore Dryers
When you press the start button the dryer hums and doesnt turn
first thing you need to do is open the door and try to rotate drum by hand it it is not turn by hand that mean there is some thing stack in your blower fan. if you can turn the drum by hand you need two people to check this problem..one open the door there is one push button, push that button and hold now second person need to push the start button when you heard hums sound the turn the drum by hand again if your dryer stat spin that mean you have bad motor. (forgive me for my english)
Apr 18, 2009 | Dryers
General Electric Heavy Duty Dryer willnot start when start button
WARNING: High Voltage may bzzt you... careful.
Your dryer thinks that it is at the end of a dry cycle.
First thing to do is disconect the dryer from the 220v mains and let it sit for about 10 min.
then, spin the timer four or five times around and then stop it at a TIMED dry cycle, not an automatic cycle. (example: 60 minutes).
Plug unit back into the wall.
SLAM door on unit and press button again...
Mar 12, 2009 | Dryers
Home Logo
676 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
