Question about Karcher 2500 PSI Pressure Washer
I have a Husky-Kohler 2600 PSI power washe that runs fine. But when the motor is turning off you have to wait till is cold to turning on again. What could be the problem?
    Scholar:
  • 90 Answers
Sounds like vapor lock
Posted on Jan 22, 2013
2 Suggested Answers
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
Husky 2600 psi with Kohler Courage x7 173cc engine. Why does it leak gasoline?
Bad gas line, loose gas line clamp, cracked gas tank. Defective bowl to carb gasket.
Mar 26, 2016 | Garden
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 | Psi Garden
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
I have a Husky power washer 2600 psi starts & runs until it seems to build Pressure and will not spray then motor boggs to a stall
Some models have a tiny orifice in the adjustable spray head.(if equipped) Which can become clogged by debris or calcium buildup. Water should flow through even when unit is off and sprayer handle(on/off) is operated if there is no water then you definitely have a clog.
Oct 31, 2013 | Garden
I have the Husky 2600 I got it to start it will run for about 10 min.then it will shut down.I can restart it then it does it again
This is sometimes caused by dirt or debris in the fuel tank, carburator float bowl or in-line fuel filter if it has one. When you start the motor the dirt is settled down and the motor runs fine. While the motor is running, the vibrations and fuel flowing through the system agitates the dirt and it eventually plugs the filter or jets. When the motor shuts down the dirt settles down and the process repeats. Replace the in-line filter if it has one and clean out the float bowl on the carb. While you have the fuel line off, let some gas flow through the fuel lines to flush them out. If dirt is a problem also check your gas can(s).
Feb 26, 2013 | Honda 2500 PSI Gas Pressure Washer
My Honda 2600 psi power washer will not pull to start. It was running great then I allowed the neighbor to borrow it. He ran the washer till it was out of gas and proceeded to refuel and at this point it...
You should be fine to take the recoil off, there shouldn't be anything that shoots out at you. You might want to check the oil level on the engine, many of the Honda engines won't start unless there is enough oil in them. If your oil level is fine, check to make sure that your motor is getting spark.
Oct 04, 2010 | Honda Pressure Washer PSI 3000
Have a husky 19 gal 1.5hp it kicks on when first start to work and when it builds up air and i use it and when it wants to kick back on it wont i have to wait till it cools down.
Is there an option for you to run this compressor on 220 volts vs 110 volts??? If so, you may want to convert it by following the re-wire instructions on the motor or wire access plate/instuction book. The reason your compressor won't fire up again after building pressure is the head pressure is to great at restart and 110 household current is not enough to give the power needed to turn the piston. You'll need to replace the plug and have someone run a 220 volt circuit once the conversion is completed.
Jan 18, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky power washer no presure?
Found an easy solution to my problem. Was dumping pressure out the bottom when I pushed the trigger. Turned out the line my hose reeler that my hose was running off of was kinked. Only partial pressure was going from the house hose to the pressure washer. I attached my house directly into the house, bypassing the hose reeler, and it worked fine. Apparently, you need a certain amount of pressure going into the washer for it to work.
Mar 20, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
292 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
