The ice dispenser rubber door or seal does not close allowing warm air back into the freezer and causing frost buildup. How difficult is that rubber seal to replace.
Remove the top freezer hinge cover and disconnect the plug there . This will remove power to the door . At the bottom of the dispenser cover , but inside the dispensing area , between the grill and the cover , insert a small screwdriver about 1 " in on both sides , and push down and inward , forcing the bottom of the cover outward . Do this carefully , due to plastic tabs on the dispenser cover . After bottom is loose , lift upward , to release the top plastic slots of the cover . Disconnect the plug on the cover . Remove the 2 screws holding the dispenser housing , and slide forward . You should now be able to see the door flap , return spring and pin . You will have to see which part(s) are needed or what the situation is . Maybe pin slid out , maybe the clear plastic ice guide , connected to the dispenser activator arm , broke loose , obstructing the closure of the door flap . Come back with your findings and a model number , and myself or another expert , will be glad to give you part numbers .
Lever is broke on the coffee reserve tank. I do I replace this part?
I have the same problem and my 47374 is only 5 months old. The lever is broken off the closer. Don't know how this happened but I would like to get it fixed. The solution is to buy the coffee dispenser unit but so far I can not find anyone that has that part or any parts for any non-commercial coffee pots. Where can we order the part???
Contact me at [email protected] if you find a place to order a replacement part. Thanks.
