Question about Ricoh Aficio 2035 Copier
SC 995 the machine stopped when connect printer cable
    New Friend:
  • 12 Answers
Possible Cause:
The B135 (35 cpm) and B138 (45
cpm) use different controller boards,
and the IOB DIP SW settings must
be set correctly for the machine
speed
Posted on Feb 05, 2013
2 Suggested Answers
M2Tech1
  • 313 Answers
SOURCE: mpc 1500s sc 202 and af 1075 sc 995
are you sure the codes SC202 is ink related and you need to check the covers on the cartridges as the ink has run out...or the head is not recognising the cartridge..
the sc995 is due to a NVRAMM missmatch or failure.. the serial numbers are not recognised.. if you have replaced the controller board it is not correct or faulty. you can get a sd card and do SP5825 to download new details to the new NVRAMM
Posted on Jul 14, 2010
Sc 995 ricoh mp4500
This error code can mean several things. However the most likely problem has do do with the finisher attached to the copier unit. The finisher may have been disconnected to the bridge unit or lost power. Check your connections to the finisher and make sure it latched to the main unit properly.
If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer and copier maintenance repairs, leasing and supplies.
Oct 24, 2015 | Ricoh Office Equipment & Supplies
Ricoh mp 2550b sc 995 solution
SC995 Serial Number Setting Incorrect The 11-digit serial number is printed on the data plate. This information is compared with the installed components to detect mismatches. Did you remove any of the machine parts or components? Reinstall anything you removed and see if the error is resolved. If it's a problem with the NVRam, you'll need to contact an expert.
Dec 02, 2014 | Ricoh RICMP2550B Aficio Mp2550B - Digital...
Dsm 618d
Reinstall your driver
Apr 24, 2012 | Gestetner DSm618d Copier
Mpc 1500s sc 202 and af 1075 sc 995
Jul 10, 2010 | Ricoh Aficio 1035 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
PROBLEM SC 995
Information Type 995 machine • Wrong
After switching on the machine, was detected with the controller card
mismatch CPM correct information sent by the Engine Controller.
Solution: Replace the controller card with the correct tab.
Jun 08, 2010 | Ricoh Aficio 3025P Black and White Copier
Thermal Printer for Royal 600/601 sc Cash not printing
do you have tape in backwards? one side will print other side will not.
Jun 28, 2009 | Royal Office Equipment & Supplies
Machine shows a service code of sc 928
The SC - 928 is a Memory error problem.
The machine detects a discrepancy in
the write/read data during its write/read
test (done at power off/on and at
recovery from low power or night/off
mode). To try to reset this code -- Turn the MAIN power switch off, wait about 30 secs. then turn switch back On.
Possible causes:
• Memory defective
• BICU defective
• Poor connection between BICU and
memory
The cheapest repair would be to replace the memory. It is rare the the connections came apart unless some one was in the back of the machine for some reason.
Jan 20, 2009 | Gestetner DSm615 Digital Imaging System
Have a ricoh aficio 450 and there is error code sc 623?
1. With the machine turned off. Go to the back of the machine and disconnect the cable that goes to the paper deck.
2. Turn on machine.
3. Turn off machine.
4. Reconnect the cable.
5. Turn on machine.
6. If problem continues you need the BICU
Dec 17, 2008 | Ricoh Aficio 450 Copier
SPANNER SYMBOL ON MESSAGE PANEL
What SC code is the machine giving? Watch the LCD display and the machine will give an SC Code. Let us know this and we may be help to further.
Mar 10, 2008 | Ricoh Aficio 1018 Printer
Ricoh Aficio 2035 Copier Logo
425 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
