Question about Huawei u8661 dual sim
Huawei U8661 Charging Problem
I charge with Phone charger, battery level is going down and empty, i already checked my charger and battery, also change new battery, but can't fix it, I can use full level battery with phone normally, so now if i want to charge, power off, take battery and charging with universal charger :(
  • yoolay88
    yoolay88 Feb 23, 2014
    yoolay88@gmail.com
    New Friend:
So do i..
Posted on Feb 25, 2013
2 Suggested Answers
  • 520 Answers
SOURCE: how to unlock Hawei U8661
Hello My Dear:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Jan 04, 2013
Hi My Huawei wont charge
fone fell if screen doesn't respond digitizer has gone bad, charger port also damaged I'd recommend getting a new device since it will cost alot to repair that
Apr 18, 2017 | Huawei Cell Phones
My Huawei U8730 phone
charger isn't charging enough
Jul 16, 2015 | Huawei T-Mobile myTouch Q - Black
TracFone is charged, but says it is not charged and will not turn on.
Hello':":":":"
PHONE CHARGING:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
2:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 20, 2013 | LG Cell Phones
Can I update Huawei U8661 to ICS?
I want to upgrade HUAWEI U8661(version 2.3.6)to ICS version,so help me.
Dec 24, 2012 | Huawei Sonic Plus U8661 Dual Sim 2 Line...
Have 2 lights on charger. One power, the other says charging. Both come on but after about 15 mins the charging light goes off. Does this mean the battery is charged?
so no lights go green, it depends on the charger however in my experience all of the charger i have repaired have a green light to show fully charge, is it possible to try another charger ? this could imply a faultly charger , can you check the battery voltage anywhere from 26 volts DC to 28.3 volts DC no more otherwise you shorten the life of the battery. You really want the voltage level to be near 28 volts that way you will get maximum distance as well as prolonged life of the batteries in question.
Regards
Please leave feedback.
Dec 19, 2012 | Pride Mobility Products Go-Go Elite...
Phone is using more current than the charger is able to deliver
First Option:
Second Option:
Dec 02, 2012 | Cell Phones
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
Second Option:
Jul 26, 2012 | Huawei Impulse 4G
My nokia x3 wont charge properly. i got the battery changed twice and also got a new charger, but still it wont charge completely. as in, till its connected to the charger it will work, but when it is...
Good day. if you have tools with you, check first the charging pin at the side of the phone unit, sometimes its the PIN inside not in proper position, or check the terminal IC of the charger. But if you cant handle this problem by yourself, i might suggest you must go to your nearest cellphone personnel at your area, coz its too complicated and it required a proper tools. thanks
Sep 11, 2011 | Nokia X3 Cell Phone
Huawei u8661 dual sim Logo
431 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
rostit
 Brian Main
Brian Main
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
