Question about Kodak EasyShare P850 Digital Camera
Lcd screen comes up in spots
Ok got my camera working thanks to the dehumidifier , and some solutions posted here next questtion how do you open this camera , i have all the screws out ,and all i need now is to open the camera from the top end, my lcd screen comes up in blotches , ie from the rain damage , can that be fixed , or do i need a new screen . kind regards , for any solution posted . CH
  • Ciaran Harte Jul 27, 2007
    problem solved , just straped it to a dehumidifier, for 2 days, then left it in a warm place and dryed out the screem , thanks any way
  • 28 Answers
The P850 has two hidden screws under the eye view finder. You need to remove the rubber eye piece by removing the two screws and pressing in a downward direction. You will see the two holes for the screws.
Posted on Oct 10, 2007
    Problem Solver:
  • 13 Answers
Once your LCD has gone blotchy, that means its probably time to get a new one. Water has either leaked inside and ruined it or there is damage in the wiring. As for opening your camera, once all screws are out, it usually a matter of clips on the inside that snap the 2 halves of the camera together. I don't own this camera so I would suggest using a small flat head screwdriver and gently prying around trying to find the clips.
Posted on Jul 27, 2007
SOURCE:
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
CANT GET THE FRENCH TO TURN OFF ON MY ACER 5251-1953 FOR THE KEYBOARD THE QUESTTION MARK WILL NOT WORK
  • Click Start and then Control Panel
  • In Control Panel, if you are in Category View, click on Switch to Classic View
  • Open Regional and Language Options in Control Panel.
  • Click on the Languages tab.
  • Under Supplemental language support, select the check box beside the applicable language collection
  • Click OK or APPLY
  • Restart the computer
Sep 17, 2010 | Computers & Internet
Black spots on LCD screen
you need to make sur about something:
the black spot, is it a dead pixels?
if it's not, canon will fix it for you free of charge as it could be a CCD problem.
Jun 26, 2009 | Canon PowerShot SD880 IS Digital Camera
Lcd screen has black spot inside, outside fine, takes pictures
you should replace the lcd screen from an authorized service center. or you can buy the lcd screen alone from ebay and find someone to replace it .remember
never open the camera unless you know very well how to replace it.thanks for using fixya. please dont forget to rate my solution
Jun 01, 2009 | Fuji FinePix J10 Digital Camera
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Haier Dehumidifier stuck on 45
Check the coils at the back of the dehumidifier to see if there is any frost buildup on it. If there is, turn off the machine for a while until the room warms up and melts off the frost. The machine works by condensing the moisture in the air over these coils, so if the coils are frosted over, or are not cold enough, the moisture cannot condense. If the coils are not cold enough, you may want to get it refilled with refrigerant. You will need to take it in for servicing in this case.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 29, 2008 | Haier HDN655E Dehumidifier
Tank full light flashes & unit will not operate, but is attached to a hose
If you get a fault code CH 01, check the posting for that solution and see if it helps.
Sep 07, 2008 | Comfort-Aire BHD-501 Dehumidifier
Kenmore Dehumidifier
I wonder if a little squirt of WD40 would go a long way in preventing the rust problem?
Sep 01, 2008 | Kenmore 54701 Dehumidifier
Dehumidifier does not collect water.
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Cheers!
IrishDruid
Aug 05, 2008 | Haier HDN655E Dehumidifier
Kodak EasyShare P850 Digital Camera Logo
65 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
