Question about Microsoft Office 2003 Pro (269-07387) for PC
Does anyone have clue about the " Pro.Msi" File
  • 156 Answers
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
Does anyone have clue about - default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Posted on Jan 24, 2009
Please insert usb flash disk with BIOS file
You need to use a computer with Internet access, then go to the MSI WEB site to download the BIOS file for you model motherboard and then copy this BIOS file to an USB memory stick.
You and then insert this USB memory stick into your MSI computer and boot up the computer.
May 14, 2013 | MSI K8N Neo4-F Motherboard
The camera in y loptop MSi
An MSI File is an installation file for a windows application, it can't find that application because you don't have that application on your computer. You're going to have to search for the driver for it online.
But then again, I have no clue what you're asking.
Feb 25, 2013 | Computers & Internet
Hi, From where can I download a manual for a 694T Pro VER 5 ?
Verify that the correct model is MSI 694T Pro.
You can download it directly from MSI support site. Click here to download. Its ver. 5.
If the link does not work, go here and select your desired language to get a download link.
Note: the manual is a pdf file enclosed in a zip file. Extract it first.
Dec 06, 2010 | MSI Computers & Internet
Hello, I am trying to find the file PRO11.MSI in my computer. What do i do to fix the problem i am uable to use excel.
The PRO11.MSI File will be on the CD that you used to install Office.
Hope that helps, pls rate the solution
Nov 11, 2010 | Microsoft Office 2003 Pro (269-07387) for...
My microsoft office 2003 requested for a file named pro11.msi. now i want to download it.
You cant download PRO11.MSI. PRO11.MSI is a file that come with your Office 2003 installer. So try to look it on your CD or on your harddrive.
for more information regarding how to download pro11.msi refer the below website
Nov 06, 2010 | Microsoft Office 2003 Pro (269-07387) for...
1706 need PROPLUS.MSI file fix/patch to run xp pro
I am not sure what exactly you need.
I suppose PROPLUS.MSI file is a Microsoft Installation Pack for MSOffice XP.
Incase you have a CD for Office XP and that particular file is corrup, you can download the same from the following link:
Similarly you can download all the files of the Office XP disk from this link:
If you need any further help pls feel free to get back to me.
If this is what you were looking for
Please do not forget to give your feedback and say thanks
Sep 04, 2009 | Microsoft Windows XP Professional for PC
Pinning layout for Micro Star WS 6330 motherboard
Hi Hunter45,
Download the manual from MSI, click on the link below.
MSI K7T Pro MS-6330
You'll need winrar or winzip to uncompress the manual & you'll find there are 5, *.pdf files rather than just one for the hole manual.
File name: 6330-1.PDF will show the MB layout. Page 1-4.
You ca see the 2 USB pins to the left of JMDM1.
JFP1 close up;
Open file 6330-2.pdf, page 2-22 for the pin layout for the MB USB's.
If you need more information, post here.
Good luck Hunter45!
Thank you for trying FixYa.
Jan 19, 2009 | MSI MS-6330 Motherboard
Problems installing ms office pro 2007
hi Error 1706 is a Microsoft error that is sometimes generated when you install a Windows package from some form of removable data. Examples of removable data would be a CD-ROM or a DVD. Typically, the exact text of Error 1706 will include the phrase "no valid source could be found."
One of the usual causes of this problem is that the Windows Installer or MSI file is not residing in the root folder of the media that is found on the removable data. This does not mean that the MSI file is not somewhere on the media -- just that it is not in the folder that your system is checking. While, in most cases, the Media Package Path would be altered to create a clear path to the MSI file.
thank you
Oct 05, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Office 2003 Pro (269-07387) for PC Logo
821 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
