Question about Garden
My Merry tiller refuses to start
Occasionally my Merry Tiller starts but only runs for a few seconds, but its more normal for it to not start at all, also the plug gets clogged with oil after trying to start it
  • 48 Answers
SOURCE: My tiller won't stay running
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Posted on Oct 17, 2008
SOURCE: yard machine tiller won't stay started!
There is a small diaphram on the side of the carb that simply wears out. It's rubber coated mesh and the rubber coating breaks down and it stops pumping fuel into the carb. Sometimes you can run with the choke on partially, but it will burn 10 times the amount of fuel and cause more damage to the engine itself. I think it's about a $10.00 part.
Posted on Dec 08, 2008
trippssmengi
  • 76 Answers
SOURCE: Tiller won't start
You may need to perform a rebuild or possibly a good cleaning on the carb. any questions on it feel free to ask
Posted on Mar 17, 2009
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
Posted on May 05, 2009
  • 48 Answers
SOURCE: Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Posted on Apr 16, 2010
Why won't my brand new tiller stay running? Starts, runs a few seconds, then stalls.
sounds like its flooding
the float needs adjustment or seat needs cleaning or replace
May 31, 2014 | Mtd Products Yard Machines 158CC Tiller
The tiller starts but then immediately stalls after a few seconds. I have cleaned the air filter and changed the gas without any benefit. the tiller has only been used a few times
me too...does your engine get abnormally hot? My F-I-L says mine's a bad carburetor. $60 replacement + shipping. I may give it a try...sad though...I don't think I have more than 3 hours run time on this stupid thing. (MC43)
Apr 29, 2011 | Ardisam Earthquake Mini Cultivator 43cc...
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
My 6 HP Craftsman tiller will not run without starting fluid
Carberator is gummed up and will need to be removed and dismantled and soaked in solvent for an hour or two.
Aug 16, 2009 | Craftsman 8.50 Torque Rating Dual...
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Engine runs backwards?
Starter clutch needs to be cleaned or replaced. What is the model # and type # on the engine
May 17, 2009 | Husqvarna Garden
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
166 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
