Samsung m3 portable external hard drive not showing in my computer
I have recently bought the Samsung M3 Portable External Hard Drive 1TB. When I plug it into the USB port the message bubble shows up saying that it has installed successfully and is ready to use. However, it does not show up in 'My Computer' when I open it. After a bit of searching, I found it in 'Devices and Printers' (I am using Windows 7). It will not allow me to open the drive, all I can do is Eject, Create Shortcut, Troubleshoot or Properties. I have played around with it for ages and cannot find any volumes on it to put my movies, music etc onto. The guide is not helpful as all it says you need to do is just plug it in. Any help would be greatly appreciated,
If you can's see it in Explorer go to Disk Management, right click and select option to change drive letter and allocate a letter that is not already used by other drives. No need to delete or format it, unless you really want to do it. Once you have allocated a letter to this new drive, it should show in Explorer as Samsung + your chosen drive letter.
Posted on Oct 15, 2014
  • Jamie Marsh
    Jamie Marsh Aug 29, 2015
    This worked instantly.
    Thank you!
Even though the thread is very old, I will share this here for anyone else googling this problem. I have fixed my Samsung M3 Portable HDD this way in Windows 7:
NOTE: This method will wipe any data on the HDD, if you have valuable data on it, do not proceed to do this, only proceed if you do not care about loosing data and want your HDD to work again!
1. Opened ''disk management'' (used start search bar, typed in ''disk management'' and ''create and manage hard disk partitions'' option came up, clicked it.
2. Now, the hard drive was with no name, but I could see it's size and it said it was a healthy primary partition. I guess that means it works.
3. It had only two options when I right-clicked it, properties and delete. I chose delete.
4. It then proceeded to tell me the partition was created using a different OS than windows (that is why windows did not recognise it), I ignored the message and proceeded to delete the partition.
5. Once deleted, I selected the drive this time from the bottom part of disk management, right-clicked it and chose new simple partition (using memory at this point, wording may be slightly different).
6. From here it was mainly clicking next as all settings are good by default on Windows 7, once complete, the HDD was ready to use and I could access it.
Now this may not work for everyone, but I hope this will help some of you who have the same problem since I found nothing on google myself.
Posted on Jun 14, 2014
Try going Start -> Control Panel -> Administrative Tools -> Computer Management -> Storage -> Disk Management (This is for Windows 7, the process might be a little different for other Windows versions).
With any luck you will see your 1TB partition on here. You can then right click on it and select 'delete volume' if necessary, and then format it. Make sure you are formatting the correct partition.
The issue for me was that Windows did not recognise the partition on the external, and therefore was not displaying it because it assumed it was data from an unrecognised filesystem, and therefore didn't want to mess with it.
Posted on Feb 11, 2014
  • Ryan Ryan
    Ryan Ryan Feb 11, 2014
Hi, I have the same problem, did you find a solution? Many thanks
Posted on Feb 03, 2013
bob_computer
  • 3153 Answers
SOURCE: my external hard drive is not showing up
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 02, 2009
SOURCE: Acomdata Portable Hard Drive
got an answer on ask.com
Posted on Feb 20, 2009
zzptichka
  • 95 Answers
SOURCE: My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Posted on Dec 30, 2008
  • 3799 Answers
SOURCE: My windows 7 (x64) will not Acknowledge My AcomData HD250FAPE5-72 External Hard Drive, What do I do.
Having looked at the review of this device, it doesn't sound good. There is a problem with these but if it shows up in explorer you can use it. The other problem is that it is not windows 7 recommended. Have you tried to use it with the firewire connection? You may have better luck, but Windows 7 has to have "Signed Drivers" for all hardware (they have to be vetted by Microsoft) Good luck.
Posted on Mar 20, 2012
Testimonial: "Well, You didn't exactly fix the problem, but you did confirm what i had suspected, I just needed to hear from somebody else. Especially someone who knows more about computers than i do. Thank you for your help. By the way Mr. Michael Green, so that i can figure out what to do with this external hard drive. What Type, Model & Make of computer to the best of your knowledge was my external hard drive Intended for? Sincerely Yours, Aaron J. Baker. "
lock123
  • 6831 Answers
SOURCE: I have a Iomega 500G
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Posted on Feb 15, 2011
I've got a samsung m3 portable that has suddenly stopped being recognised
it is not uncommon for external hard drive enclosures to fail. If its not working on multiple computers, this is probably the case. try it in 1 more computer and if it still doesn't work, I would do the following:
1. Open the enclosure to expose the actual Hard Drive and obtain the model number and note the size. if its a laptop hdd, its 2.5". if its a full size hdd like in a desktop pc, its 3.5". the enclosure may be screwed together but likely snaps together.
2. Google the model # to determine the interface and speed (likely SATA 3.0gb/s but could be SATA 6.0gb/s
3. Go to Newegg.com or Amazon.com and buy a new external hard drive enclosure ($5-$35) with the same interface, speed, and size as your hdd (use the filters on the left to narrow your search)
Home Computer Hardware Computer Cases External Enclosures
4. Put your hdd in the new enclosure and check if its working.
Mar 07, 2014 | Computers & Internet
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
Samsung M3 Portable Drive Diagnostic Fail Message
I would try creating a new folder (maybe TEST) on your portable drive, and saving 3-4 files (as copies) from your hard drive, say, a MS Word file, an Excel file and a .jpg picture. Close down your computer, remove the portable drive. Then start up computer again, when ready insert portable drive.
See if your computer recognises it, and then try to open the files you saved onto it. If that is OK it sounds like you do not have a problem. But treat it with caution for a week or two.
Jan 11, 2014 | Computers & Internet
Hello! I recently bought a samsung portable
The software is telling you one thing and the Webmaster another. I would trust what the software error is saying to you. I can't even register my Samsung Tab 3 on their site, it asked me to enter the purchase date which I did, 11/16/13. When I tried submitting the form, I got an error telling me the Tab 3 was manufactured 11/30/13, making my purchase date incorrect. Really??!!! My Best Buy receipt didn't lie and I was there at the store that very day, and had purchased the Tab 3.
Oct 23, 2013 | Samsung M3 Station 1TB 3.5" External Hard...
How do I play downloaded movies from Samsung M3 Portable hard drive to tv
Most TVs will play AVI movies from USB connected drives except Sony TVs. Sony has prevented downloaded movies playing on their TVs.
Jan 27, 2013 | Computers & Internet
Hello, I formatted my external hard drive Samsung G2 HX-MU050DC and i lost the drivers. I can not find drivers. Can you help me please? Because i can no longer read the files that are on it. Thank you...
According to the microsoft site your external hard drive which is the Samsung G2 HX-MU050DC doesn't need any additional software it is automatically installed when connected..Maybe try to connect it to other USB port I preferred you connect it at the back of your CPU..If this doesn't work try to connect your external hard drive to other computer if it still doesn't work. sad to say but the problem is your external hard drive..
Jul 06, 2011 | Samsung G2 Portable External HX-MU050DC/...
My Samsung HX-MU010EA/G2 1TB portable hard drive is not working. It is not being recognised by my computer all of a sudden after about 6 weeks of use. The blue light flashes quickly but does not give...
Have a look in disk management if on win 7 or vista just type in "disk Management" in your search bar after clicking start button and see if it shows up there. If not try plugging into another computer and see what happens. If still no good you say only 6 weeks it should be guaranteed. If your data is important to you never trust just 1 source of backup maybe start copying to DVD's also. Good luck with it from Scott
May 17, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
Computers & Internet Logo
14,178 people viewed this question
David Payne
David Payne
