Hitachi hdr505 display shows 0000 and is running but won't respond to remote
The recorder is still running, can't make it turn on off or function in any way. Have turned it off over night, have changed batteries in remote, but no change.
dsacco86
  • 1077 Answers
SOURCE: Samsung LN32B360 32" LCD HDTV (Black) DOES NOT POWER ON
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, it maybe something simple like a blown fuse inside the TV. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 14, 2009
SOURCE: can't turn tv on with remote, only manually, when on volume is at 100 and cannot be adjusted with remote or manually. channels cannot be changed with remote or manually. Changed batteries in remote,
replace with new batteries and it works --- so simple
Posted on Sep 22, 2009
budmrtn
  • 11361 Answers
SOURCE: TV doesn't respond to the remote control...can't change channels
You have to find out if the remote is sending out the infrared signal to the TV remote receiver or not, you can test that by pointing the remote at the digital camera, you should see flashing light on the camera screen when any one of the remote button is pushed (digital camera can detect infrared light). If get the flashing light then the problem is in the TV remote sensor.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 15, 2010
  • 4 Answers
SOURCE: sharp aquos lcd, 6 months old. TV will not
try unplugging tv.
Posted on Nov 27, 2010
  • 517 Answers
SOURCE: My sanyo hdtv shows no pictures when you turn it
Good day!
The problem of your TV could be the inverter board or the cold cathode light is busted.
Follow this instruction on how to fix that problem:
  1. Remove the back cover of your TV.
  2. Look for the Inverter board.
Inverter board looks like this:
3. Check the input voltage of the inverter board if have 24vdc.Using multimeter (range on DC)
4. If you have 24vdc,check the output voltage of the inverter board it should have 500vdc.
5. If you don't have 500vdc output on the inverter,replace it.
6. If the you have the output voltage on it,the problem could be the busted cold cathode light (C.C.T).Replace it.
I hope this solution will be helpful.Thank you and don't forget to rate my answer.
Posted on May 07, 2011
Displays 'no signal', no picture
Try unplugging the set and a box if connected to it for a while, plug both back up allowing possible reboot as either could cause this problem.
Dec 04, 2012 | Televison & Video
Hitachi 51S700 won't turn off
Some kind of a problem likely in the magic focus area--is the set showing a error on screen if you engage the magic focus?
One thing not to do is disconnect the sensors inside the screen as that could make things worse......
Dec 02, 2012 | Hitachi 51S700 51" Rear Projection...
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
Friedrich AC turns on but won't run
Sounds like the inverter pcb, but may have lost gas. Get it checked by a tech
May 14, 2012 | Heating & Cooling
I want an instruction manual for an Hitachi HDR505 set top box
My Hitachi freeview + recorder hdr505 keeps freezing when i go to tv guild to set to record programs
Mar 31, 2012 | Televison & Video
My Hitachi Digital TV Recorder (HDR255) is just displaying 0000 on the panel and does not respond to the remote at all. There's a little green light on the left hand side of the panel. There is no...
I have had the same problem with my tv recorder box. The problem seems to occur when the box freezes up when accessing the recordings library. I unplugged the box a number of times [be patient it could take up to twenty goes] and eventually I got a picture and sound. I reformatted the hard drive and the problem has not been seen since. I am a little paranoid about unplugging the box as I fear it will reset it back to the original situation. Hope this helps people.
Jul 04, 2011 | Televison & Video
MojogiMy GHD1621F2 freeview recorder is frozen on one programme, won't respond to the remote at all (have new batterys) and won't respond to buttons on front. Turning off and on doesn't work...
Hi mojogill,
It sounds like the receiver may be locked up. If the buttons on the front do not work, then try unplugging the receiver for 5 seconds and plug back in then check to see if everything is working fine.
If you need any further assistance with this, feel free to contact me at thomas.faust@dishnetwork.com. Thanks!
Tommy Faust
DISH Network
May 25, 2011 | DISH Network ViP722 DTV Receiver /...
The VCR won't record from a digital terminal.Connection Made according to instructions.Both VCR &digital terminal on channel 03.If the digital terminal is by-passed the recorder works fine.
use scart lead put one end into the digital ( BOX or TV ) out put ( AV1 or AV2) and the other into (AV1) on vcr then change the mode so AV1 shows on vcr display
you can do this by pressing button on remote marked with ( input / source or a picture with a arrow pointing into a tv
you can only record the station that the digital box or tv is on if you turn over vcr will record that station
Dec 16, 2009 | Hitachi VTFX6510A VCR
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
