Question about Luggage & Travel
What is a trolley case? - Luggage & Travel
    Genius:
  • 1,669 Answers
Here are some examples:
http://search.aol.com/aol/image?q=trolley+case&v_t=amonetizetest1-ie
Posted on Jan 16, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
This is a suitcase that has a handle at one end and two wheels on the other end. It is meant to be pulled vertically.
I have a craftsman garage door opener 1999. it goes two feet and then back down. I can open door with one hand. all gears are new as i rebuilt it (Twice).
Your "timing" is off. Disconnect the door from the trolley and tie down the door latch assembly so it does not engage the trolley. Then using the up down button on opener open or stop the trolley at the closest position you can to the motor assembly. Then open the door to the position it would be when open and note where the latch is at that point. Then loosen the drive and move the trolley to the position noted in former step.- then tighten the chain.
Now hook up the door latch to the relocated trolley and play with the up/down adjustments till you get it right.
Jun 11, 2017 | Building Materials
Runaway trolley problem?
In The Wrath of Khan (1982), Spock says, "Logic clearly dictates that the needs of the many outweigh the needs of the few."
https://www.theobjectivestandard.com/2013/09/spocks-illogic-the-needs-of-the-many-outweigh-the-needs-of-the-few/
Jan 04, 2017 | Homework
Where is a safe trolley jacking point on the front end of a peugeot partner
THE ONLY SAFE WAY IS TO JACK ON THE FRONT CROSS MEMBER,AND PLACE TRESSELS ON THE CHASSIS(SAFETY FIRST)
Jan 04, 2013 | Peugeot Partner Cars & Trucks
The inner and outer trolley will not reconnect
If the rope is pulled down and back toward the motor unit the trolley latches in the released position. To unlatch the trolley pull straight down on the rope and release. The two halves should now click together.
Feb 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door can be opened manually when the trolley has
You can adjust the length of the arm between the trolley and door so that it is in a vertical position when the door is closed. This will prevent your problem.
Oct 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener 1/2 hp will not open door
It sounds like your chain is out of sync with the limit switches. Loosen the chain enough so that you can remove it from the sprocket on top of the motor unit. Now run the opener until the sprocket runs counterclockwise and stops. Now with everything attached and the door in the open position replace and tighten the chain. You are now in sync. You may need to tweak the up and down limit controls which are on the side of the motor unit.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens 1 foot, then stops.
It sure sounds like you have a broken door spring. While you are at it remove the cover and take a good look at the drive gear. It is white nylon and is just in front of the motor. Might be stripped and unable to take the weight of the door.
Jun 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens all the way only closes half way down
Some of your comments look like they're missing but from what I can see you had to put chain back on and now the door doesn't close all the way.take the cover off and look at the limit switch,this the travel adjustment. The switch for the close side is making contact too soon so it shuts off early.You need to adjust contacts so its further away. Depending on where the trolley was when you reattached the chain, you might not be able to adjust it back enough.But try it first. If you still come up short you will have to take the chain back off and move the trolley back to where the door would be closed and reattach chain. now open position will probably need adjustment leave door unhooked and just let trolley move in case it over shoots the mark either way.
Apr 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener, chain adjustment
Loosen the inner nut on the trolley. (That is the lock nut). Then tighten the outer nut on the trolley to increase tension. The outer nut on the trolley is closest to the garage door. The chain tension should be 1/2 inch off the rail at midspan. (The chain is fastened to a threaded bolt on to the trolley. The threaded bolt has an inner and outer nut). Hope this helps.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't go down because of interference
IF YOU ARE TALKING ABOUT THE JOINTS IN THE RAIL THE TROLLEY TRAVELS ON THEY USSUALLY ONLY GET OUT OF ALIGNMENT WHEN THE BOLTS THAT HOLD THE SECTIONS TOGETHER ARE LOOSE.
Dec 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Luggage & Travel Logo
109 people viewed this question
Top Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Luggage and Travel Expert? Answer questions, earn points and help others
