Question about Sharp QS-2760A Calculator
Sharp qs-2760a not printing dark enough
It doesn't seem to be striking hard enough to print dark enough. I know it's old, but the new ones just arnt the same. is there any adjustment i can make?
3 Suggested Answers
  • 12 Answers
SOURCE: Trying to purchase
You can purchase it from:
http://www.shopping.com/xGS-Sharp_Qs_2760a~NS-1~linkin_id-8001698
Posted on Dec 23, 2008
  • 102366 Answers
SOURCE: I don't have manual for
You can download the manual from the manufacturer's web site at
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_QS_1760.pdf
Posted on Aug 11, 2011
I don't have manual for SHARP Compet QS-2770A. I want to set decimal to always print 2 decimal places when I enter a number. Such as: enter 1234 and it prints automatically 12.34. Is this...
Aug 11, 2011 | Sharp QS-2770A Calculator
My eltron ip2844 wont print dark enough. I went into setting and turned the burn darkness to 15, but still not dark? Help!!
This may be due to your thermal paper.
This printer doesn't deliver enough heat to your paper or you have a problem with the head pressure.
Press on the bloc while printing to see if it's this reason?
You may also have a mis-alignement of the thermal head.
Try also to change the print speed?
Aug 05, 2011 | Zebra Eltron LP 2543 Thermal Label Printer
Installed new ribbon and now the keys don't seem to be striking hard enough - nothing shows
The plastic print solenoid cap is probably broken. We sell the cap with shipping and instructions for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Nov 16, 2010 | IBM Wheelwriter 6 Typewriter
Omni 3740 not printing dark enough
The print on our Omni 3740 is not working. We have to push the cover down hard to make it print. I think the roller is not pushing hard enough or the clamp to hold the cover is out of alighnment. Need help.
May 26, 2010 | Office Equipment & Supplies
Wheelwriter 30 series 2.
Put in a multi part form and type if the print is good on the carbons the problem is ribbon or ribbon lifting, if the print is poor the print solenoid cap is probably cracked. We sell the cap with instructions and shipping for 20.00.
DickyO
216-241-0027
Feb 09, 2010 | IBM Wheelwriter 30 Typewriter
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Errors??
Sounds like the printwheels are out of time. Sorta of major repairs. gears on side of printer have to be lined up in proper areas. there are small black arrows on the gears. Best bet is look at a working machine and try to line up. Machine may not be worth the time unless you jsut want to try it. Sharp uses the same printers in many different models.
Jun 21, 2008 | Sharp EL-1611P Calculator
Sharp QS-2760A Calculator Logo
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
