Question about Toshiba Satellite L305D-S5914 Notebook
L305-s5914 wireless problem
Cant get wireless to work
  • tanderson845
    tanderson845 Jan 18, 2013
    Thank you for the information, I had to run all the updates and when I did that it resolved my problem, Thank you Sir/Maam for your help.
  • Brian Sullivan
    Brian Sullivan Jan 18, 2013
    no problems hope it all goes well now
  • Toshiba Master
  • 27,725 Answers
Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx Hope this helps.
Posted on Jan 16, 2013
Internet connection worked through my wireless router until recently on my Satellite L305-S5877. I have turned off my firewall to no avail. I have limited connection to the router wirelessly, but no...
First unplug all devices from your router. There should be a small button (mine is depressed with the point of a pen) on your router that is used to reset the router. I have to reset mine from time to time. Hold the button down for two minutes or so to allow it time to reset. If that does not work then disconnect your modem for a few minutes to allow it to reset Then reconnect everything in the exact reverse order that you disconnected. I needed to contact my router manufacturer the first time for help in resetting it.
Feb 15, 2011 | Toshiba Satellite L305-S5877 Notebook
Built-in wireless LAN on Toshiba Satellite L305-S5875, is there a Realtek driver available fo rthe 32-bit system?
Yes, the actual driver is for 32/64 bit systems. you can get it directly from the Toshiba website.
  • go to the main page of Toshiba ; Toshiba.com
  • click on Consumer Product
  • then click on Tech.Toshiba.com option (Last on the right)
  • then click on Download and choose the model you have
  • then FILTER to WIFI and you will see the Realtek driver for the Wireless LAN compatible with 32/64bit system.\
Thank you for choosing FIXYA.com for finding the solution.
Sep 13, 2010 | Toshiba Satellite L305-S5875 Notebook
Cant get it hooked up to the internet directly or wireless
If you had it connected by wire, check the side of the computer for a switch. This will torn on your wireless connection.
Oct 27, 2009 | Toshiba Satellite L305D-S5874 Laptop
My Toshiba Satellite L305D-S5914 monitor is blank even though the power light is on and the fan is running..what should I do???
Take out the battery and only hook up the ac adapter.
If that doesn't work then, try reseating your memory one stick at a time in each slot one stick at a time and make sure you turn the laptop on after each stick reinsertion.
If you don't get video after that then go ahead and take the dvd drive out and also the hard drive.
If you dont' get video after all of this then that means that motherboard is bad and would need to be replaced.
Aug 09, 2009 | Toshiba Satellite L305D-S5914 Notebook
My wireless internet doesn't work, and the on/off switch is turned on
Hi,  Please do the following: Start>Run>type devmgmt.msc>under device manager>Right click on Wireless network adapter>uninstall, once done, click on scan for hardware changes on top. the network adapter would be back on its place. If that doesn't resolve the problem, reinstall the driver for wireless network adapter using the link given below: http://www.drivershq.com/Drivers/Toshiba/Satellite/L305-S5894/4183/9941/42341/Drivers.aspx
hope this resolves your issue.
your feedback is appreciated. Askari :)
Apr 22, 2009 | Toshiba Satellite L305-S5894 Notebook
Toshiba Satellite L305D-S5914 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
